1841 router
a.kachroo
hello everyone,
see i have two new 1841 routers with wic-2t and wic-1t.These routers are connected via vsat link.ports of vsat modem are rs-232.I am using smart serial rs-232 dte cable at one end(router with wic-2t card) and normal rs-232 dte cable at other end(router with wic-1t(60 pins).
We have changed cables and cards at both ends,but our ports are not coming up(protocols remains down).
Needs suggestions,if anyone has done the same.And are these routers compatiable with RS_232 standards.
Arun Kachroo
mchin345
Level 6
Level 6
Try adding the command
ignore dcd
in the interface and I guess it will work.
