1841 show dsl interface command
johnlloyd_13
Level 9
Level 9
hi all,
i'm trying to troubleshoot one of our site today and can't seem to issue the show dsl interface command on a 1841 router. could someone advise if the same command is used for SHDSL or am i running with an IOS bug? thanks in advance!
#sh dsl?
% Unrecognized command
#sh ver
Cisco IOS Software, 1841 Software (C1841-BROADBAND-M), Version 12.4(15)T7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 13-Aug-08 15:42 by prod_rel_team
#sh inv
NAME: "chassis", DESCR: "1841 chassis"
PID: CISCO1841         , VID: V05 , SN: FHK13212639
NAME: "WIC/HWIC 0", DESCR: "WAN Interface Card - ATM (With multi line G.SHDSL module)"
PID: WIC-1SHDSL-V3     , VID: V02 , SN: FOC132041KD
2 Accepted Solutions
darrenflynn
been a while since I touched these but from memory I think its show controller dsl x/x
Sandeep Choudhary
Have you tried this:
Have  you tried this::::show dsl int atm <>
or
                               Show controller dsl <>
Please Rate if it helps.
darrenflynn
Sandeep Choudhary
or
Hey guys,
Thanks for your inputs! I think I remembered using the show controllers command but it's not there. I'll check this router again when I get back to work.
guess it was there all along. maybe i've got used to the show dsl int on our 800s.
#sh controllers dsl
DSL 0/0/0 controller UP
Globespan xDSL controller chipset
Line Mode: Four Wire Enhanced
DSL mode: Trained with SHDSL Annex B
Frame mode: Utopia
Configured Line rate: 4608Kbps
Line Re-activated 0 times after system bootup
LOSW Defect alarm: ACTIVE
CRC per second alarm: ACTIVE
Line termination: CPE
FPGA Revision: 0xB3
