1841 Zone based Policy - but i don't see me next step
mauric
Hello Everyone
Hello Cisco Pro People!
I try here to install me 1841 Router for me 3 Client's here in house(Trust, Zone LAN), in the mean time i have read a lot of news paper, but now i dont see me next Step.
 - If connect "ZONE Policy Security Internet" to Fa0/0 i can't ping nothing outside me untrust Zone.
 - If disconnect "ZONE Policy Security Internet" from Fa0/0" so i can and have possibilities to Ping from CLI everything in Untrust Zone.
I will create with me 1841 a little "FW" that i can Need to secure me Untrust-Side, so i have think this with the Zone Based Firewall are a good Choice, so Logical Point are that me Zone Policy running any big mistake, thats me Point now..... but i dont see this.......please how are me mistake?
Please are here possible to give me here any possible help?
I made a little design of what i think from Structured Lan Topology (Untrust/Trust) and put me Run file from me Router.
Thanks for any Mesaage taht i can become!
Best regards
Mauri
10 Replies 10
at first glance, I think you forgot to add 'inspect' to your policy map:
policy-map type inspect LAN2INTERNET
class type inspect LAN2INTERNET
--> inspect
class class-default
drop
Hello gpauwen
Thanks for your quick feedback, after reading your help and modify this i
also see any mistake with ZonePair Security with "Service Policy"
 --> inspect
Thanks alot to your help
Adding also this to Zone-Pair
zone-pair security LAN2INTERNET source LAN destination INTERNET
 --> service-policy type inspect LAN2INTERNET
but now me Interface FA0/0 don't become any IP from the ISP
Router# release dhcp fa0/0
Router# renew dhcp fa0/0
Not in Bound state.
Router# sh ip int brief
Interface                  IP-Address         OK? Method Status                Protocol
FastEthernet0/0      unassigned        YES DHCP     up                    up
FastEthernet0/1      192.168.1.254     YES NVRAM  up                    up
if delete the "zone-member security INTERNET" from Fa0/0 i will become the IP from ISP
I think i have any other trubles with me Zones's or the Policy settings
i have add now the new Run file to this post.
thanks for any possible Help!
Best regards
Mauri
try and add the following:
class-map type inspect match-all ICMP
match protocol icmp
class-map type inspect match-all SSH
match access-group 100
class-map type inspect match-any LAN2INTERNET
match protocol icmp
match protocol http
match protocol https
match protocol bootpc
match protocol bootps
Hello Together
Now on FA0/0 i have the IP from ISP
And on FA0/1 the Clients from "LAN" become the assigned IP-Range.
but Tracert from Client to Internet arn't possible
Ping from Cisco Console running
Ping from Client not running
Router#sh zone-pair security
Zone-pair name LAN2INTERNET
    Source-Zone LAN  Destination-Zone INTERNET
    service-policy not configured
Zone-pair name INTERNET2SELF
    Source-Zone INTERNET  Destination-Zone self
Zone-pair name LAN2SELF
    Source-Zone LAN  Destination-Zone self
Router#sh policy-map type inspect
  Policy Map type inspect INTERNET2SELF
    Class ICMP
      Inspect
    Class class-default
  Policy Map type inspect LAN2INTERNET
    Class LAN2INTERNET
      Inspect
    Class class-default
  Policy Map type inspect LAN2SELF
    Class SSH
      Inspect
    Class class-default
Thanks to all for any possible help!
mauric
Hello Together
    Class ICMP
      Inspect
    Class class-default
    Class LAN2INTERNET
      Inspect
    Class class-default
    Class SSH
      Inspect
    Class class-default
The problem is that your zone pair INTERNET2SELF has 'self' as the destination. 'Self' is the router and nothing else. Change it to:
    Source-Zone INTERNET  Destination-Zone LAN
and check if traceroute and ping from the clients work after that configuration change.
Hello gpauwen
after change the Settings the Client PC's arn't possible to Ping 8.8.8.8
from router Cli here are possible to ping and tracert to internet.
Thanks for your Help and best regards
Mauri
you don't have any service policies configured for your zone pairs.This is what the zone pairs should look like:
zone-pair security INTERNET2SELF source INTERNET destination LAN
 service-policy type inspect INTERNET2SELF
zone-pair security LAN2SELF source LAN destination SELF
 service-policy type inspect LAN2SELF
I am desperate, I had already registered these zones and service policy already ...
Ok now these are again registered but it is still not running.
Ping and Tracert from 1841 CLI Running
Ping and Tracert from Client PC's not Running
    service-policy LAN2INTERNET
    service-policy INTERNET2SELF
    service-policy LAN2SELF
i write "self" with big letter but appair with small letters.
please i want to bring running correctly this Router.
Mauri
keep in mind that a zone must be configured before interfaces can be assigned to the zone.
I would start from scratch:
1. remove all security zone configuration from the interfaces
2. make sure the security zone configuration and security policy assignments are in place
3. reassign the security zones to the interfaces
