Join Customer Connection to register!
1763
eric10276
Beginner
1900 Series Router PPPoE Support
We are considering upgrade of our 1800 series integrated services router to a 1900 series.  We have port FE1 on our 1812 configured as a WAN interface using PPPoE to a typical cable modem.  Can one of the standard Ethernet ports on the 1941 be configured the same way, or do we need to buy a WAN interface module?  If so what type?  Thanks!
1 ACCEPTED SOLUTION
As mentioned above, identically except naming.
Please remember to rate useful post clicking on the stars below.
4 REPLIES 4
paolo bevilacqua
Hall of Fame Master
No, just use an identical configuration.
So are you saying that the two gigabit Ethernet ports that come standard on the 1941 can be configured in a similar manner to the first two ports (FE0 and FE1) on the 1812?  Thanks.
Thanks!  I will give it a try.
