1921 basic configuration --- need desperately help
christoph.proksch
Community Member
I've bought a CISCO 1921 K9/SEC a few days ago. But I'm unable to setup my first CISCO device on my own:
Network-overview:
ISP                                                  CISCO 1921                                                    LAN
192.168.15.1                    192.168.15.10               10.10.10.1                              DHCP-client
1) By using CISCO Configuration Professional I'm unable to change the default IP address (10.10.10.1)
I'd like to change it to 192.168.0.1 (with no dhcp server)
How can I change this IP address?
2) I've configured basic NAT. I can ping any 192.168.15.1 device, but I unable to ping any external IP address (eg. 8.8.8.8).
Internet access, etc. isn't working too...
Here is my Startup configuration:
! Last configuration change at 20:00:31 UTC Mon Apr 29 2013 by admin
version 15.2
hostname CISCO1921
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
ip cef
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
dns-server 192.168.15.1 213.143.96.1
netbios-name-server 10.10.10.1
domain-name 10.10.10.1
lease 0 2
ip domain name xxxxxxxx
ip name-server 192.168.15.1
ip name-server 195.202.128.2
ip name-server 195.202.128.3
ip name-server 213.143.96.1
no ipv6 cef
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$$ETH-LAN$
ip address 10.10.10.1 255.255.255.248
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description $ETH-WAN$
ip address 192.168.15.10 255.255.255.0
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 3 interface GigabitEthernet0/1 overload
access-list 1 remark INSIDE_IF=GigabitEthernet0/0
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.7
access-list 2 remark CCP_ACL Category=2
access-list 2 permit 10.10.10.0 0.0.0.7
access-list 3 remark CCP_ACL Category=2
access-list 3 permit 10.10.10.0 0.0.0.7
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
transport input telnet ssh
line vty 5 15
access-class 23 in
scheduler allocate 20000 1000
ntp update-calendar
ntp server 0.at.pool.ntp.org
end
Can anybody please give me a hint?
Christoph
You will have to paste this into the CLI of your Cisco router:
!!!This changes your LAN interface IP to 192.168.0.1/24
ip address 192.168.0.1 255.255.255.0
!!!!!This changes your NAT setup to NAT addresses coming from the 192.168.0.0/24 range to the IP address of gi0/1.
no access-list 3
access-list 3 permit 192.168.0.0 0.0.0.255
!!!!You need a default route to tell your router how to get to routes it doesn't know about.  This route will tell your router to send anything it doesn't know about to 192.168.15.1 since that seems to be your default gateway.
ip route 0.0.0.0 0.0.0.0 192.168.15.1
Once you enter those commands in via the CLI you should be all set.
Thanks Brandon,
By "ip route 0.0.0.0 0.0.0.0 192.168.15.1" NAT works really well!
Actioally I simply can not change my LAN ip address, because I only can configure my Router by LAN ethernet0/0 controller. I'm unable to configure it, by WAN-ethernet0/1 or RS232.
If I do change my IP address to 192.168.0.1 (by eg. Putty SSH or CISCO CP) the connection terminates. After that I can ping the routers new IP address, but I can not configure it anymore or surf through the web.
Have you got a hint on that too?
Christoph
ip address 192.168.0.1 255.255.255.0 secondary
then connect  with an IP in same subnet then once connected modify the NAT ACL accordingly and make the primary address in same subnet and  save your config.Reconnect to primary and get rid of secondary address and save config and you're done.
Alain
