1921 IOS upgrade failing
jjcollaguazo
HIi All,
Just wondering if anyone else has experineced isssues upgrading the IOS on a 921 router.
i'm upgrading from:
c1900-universalk9-mz.SPA.151-4.M4.bin
to
c1900-universalk9-mz.SPA.152-4.M3.
And even after stating the boot system command i get the following error below
IOS Image Load Test
___________________
Unsigned Image Found, bailing out
Signature DID NOT VERIFY
boot: cannot load "usbflash0:c1900-universalk9-mz.SPA.152-4.M3.bin"
It seems i need some digital signature and when i run the verify command i get this:
CTSGW01#verify flash:c1900-universalk9-mz.SPA.152-4.M3.bin
%Error verifying usbflash0:c1900-universalk9-mz.SPA.152-4.M3.bin: Digital signature is not present
How can i create a certificate for the new IOS? I've never had to do this for other IOS 15 upgrade?
I've confirmed the IOS is not corrupt and if i upgrade the router in ROMMON the router boots correcty.
Any help would be apprecaited.
Cheers.
jjcollaguazo
Just to let everyone know, its seems that upgrading from usbflash1 corrupts the file somehow. I tried copying the IOS from my laptop to the usb drive several times. Before doing a safe remove of the USB drive i confirmed that the md5 hash was correct. When i tried to copy from the usb to the router somehow the file got corrupted.
hope this helps others in the future.
