1921 rack mount - ACS-1900-RM-19= no longer available?
james
Hey Guys,
I can't for the life of me find any reference to the rack mount kit on Cisco's website. the 1921 used to have a rack mount kit
ACS-1900-RM-19= available, but I can't seem to order it anymore.
http://www.cisco.com/en/US/prod/collateral/modules/ps10598/ordering_guide_c07_557736_ps10536_Products_Data_Sheet.html#wp9000794
• 19-inch rack-mount brackets (for the Cisco 1921, you must order the rack-mount kit because it does not ship by default)
Is this part number still correct?
Is there a new part number?
Cheers
James
Reza Sharifi
Hi James,
The part number you have (ACS-1900-RM-19) is correct.  If you use the Cisco Dynamic configuration tool, it will give you an option to pick the above part number.  Of course you can buy it through a third party company.
So, the part number still exist as part of the confgurator.
https://apps.cisco.com/qtc/config/html/configureHomeGuest.html
