how to config cisco 857 as a public gateway?
scorpion1118
i have a set of public ip(/29) using adsl2+, is it possible to config cisco 857 as a public gateway so i can assign public ips to my computers?? before i upgrade to adsl2+ i was using cisco 678, it can be config as a public gateway without problem, but now i have ot use adsl2+, can't use cisco 678 anymore.. thank you for your help experts.....
Here you go:
ip nat inside source static 192.168.0.2 x.x.x.73
ip nat inside source static 192.168.0.3 x.x.x.75
And you will need to remove the following first:
ip nat inside source static tcp 192.168.0.2 80 x.x.x.73 80 extendable
ip nat inside source static tcp 192.168.0.2 1982 x.x.x.73 1982 extendable
ip nat inside source static tcp 192.168.0.2 1983 x.x.x.73 1983 extendable
ip nat inside source static tcp 192.168.0.2 1984 x.x.x.73 1984 extendable
ip nat inside source static tcp 192.168.0.2 8443 x.x.x.73 8443 extendable
ip nat inside source static tcp 192.168.0.3 3389 x.x.x.75 3389 extendable
Then after the above changes, please clear the existing translation table: clear ip nat trans *
The computer with 192.168.0.2 when they try to access a URL will be NATed to x.x.x.73
8 Replies 8
Jennifer Halim
You can configure NAT for those public ip (/29) that you have on cisco 857. Just have to make sure that the /29 public ip range is being routed towards your 857 WAN/Internet facing interface.
thank you for your reply....
i am doing nat now, but can i assign public ip for my computer,, so i don't need to configure nat for each port on each public ip??? and my lan can also access the server directly using the public ip or domain.
If you are assigning it directly to your computer, you would need to create VLAN and use one of the public ip on the router for your computer's default gateway.
i have a vlan now uses 192.168.0.1,i have set static ip on adsl interface using x.x.x.78/29. so the router is using x.x.x.78 now.... i had tried to set vlan using the public ip too, but it won't let me, the ip is conflicted with the adsl interface address set....
Yes, if you already assign that IP to the ADSL interface, then you won't be able to use it on another vlan/interface.
Why don't you configure static NAT instead of static PAT on the router, so you just configure 1:1 NATing for each computer which is achieving the same thing as assigning the public IP to the computer.
You can share your configuration and I can advise how to configure it. Just let me know which public ip to assign to which private ip.
ok,,here is my configuration...
Building configuration...
Current configuration : 11709 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Cisco857
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
enable secret 5 $1$NAWc$CH1VUmksNXMkkat90KfbB1
no aaa new-model
clock timezone PCTime -6
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-2303996204
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2303996204
revocation-check none
rsakeypair TP-self-signed-2303996204
crypto pki certificate chain TP-self-signed-2303996204
certificate self-signed 01
  30820240 308201A9 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32333033 39393632 3034301E 170D3132 30353236 30333433
  32345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 33303339
  39363230 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100BF21 6828CD85 E210711C 803B25AB A8925091 A9857FFD 27F41EDF 5B3AF02C
  2091C97B 5AE61741 54A5C59B CD67BBB5 BADC622C 72C66DB3 3C6EFB63 D26AD1E8
  55E8359B 20537D4E 921BF325 BF0189D1 F239F6C6 5A25A749 8F4FADF2 6C221038
  59B2E779 020BEA00 74E630F0 EB63F7A4 A27447A0 8A344173 BC8D3A49 42A0401B
  9E030203 010001A3 68306630 0F060355 1D130101 FF040530 030101FF 30130603
  551D1104 0C300A82 08436973 636F3835 37301F06 03551D23 04183016 80147DC7
  C0A62275 777DE818 ED11203D 6AF0A21A 974F301D 0603551D 0E041604 147DC7C0
  A6227577 7DE818ED 11203D6A F0A21A97 4F300D06 092A8648 86F70D01 01040500
  03818100 0611714C D40109C7 5679E67E 79E22FC4 58EC1319 B19FDE21 636DC31D
  E27333C5 7465A13C C841011A 0129F475 7C2F4B58 D45554CC 00B81B28 58E0A9B2
  94477CBA 8CF21107 E3CB9983 10A0C225 A24CD3D8 B4BE5741 7AB4217C 4B239485
  7ACBB5DB C836AD8B 44D14068 0B7B5D3B D6FEFAA3 02AFC77E 2310C0D8 83E84473 7E485DA3
      quit
dot11 syslog
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.1 192.168.0.99
ip dhcp pool ccp-pool1
   import all
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.1
   dns-server 192.168.0.2 205.171.2.65
ip dhcp pool Server1
   hardware-address 0027.0e0a.9339
   client-name Intel-i5
ip cef
ip inspect name CCP_LOW cuseeme
ip inspect name CCP_LOW dns
ip inspect name CCP_LOW ftp
ip inspect name CCP_LOW h323
ip inspect name CCP_LOW sip
ip inspect name CCP_LOW https
ip inspect name CCP_LOW icmp
ip inspect name CCP_LOW imap
ip inspect name CCP_LOW pop3
ip inspect name CCP_LOW rcmd
ip inspect name CCP_LOW realaudio
ip inspect name CCP_LOW rtsp
ip inspect name CCP_LOW esmtp
ip inspect name CCP_LOW sqlnet
ip inspect name CCP_LOW streamworks
ip inspect name CCP_LOW tftp
ip inspect name CCP_LOW tcp
ip inspect name CCP_LOW udp
ip inspect name CCP_LOW vdolive
no ip bootp server
ip name-server 205.171.3.65
ip name-server 205.171.2.65
username admin privilege 15 secret 5 $1$b8Ew$IT41ysH8Q0vre4RtpnVz2.
archive
log config
  hidekeys
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description $FW_OUTSIDE$$ES_WAN$
pvc 0/32
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 192.168.0.1 255.255.255.0
ip access-group 103 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1412
interface Dialer0
ip address x.x.x.78 255.255.255.248
ip access-group 104 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip inspect CCP_LOW out
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname xxxxxx@xxxx.net
ppp chap password 7 096156184F0D1C031E
ppp pap sent-username xxxxxx@xxxx.net password 7 11240114411A001D11
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http access-class 3
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 2 remark CCP_ACL Category=2
access-list 2 permit 192.168.254.0 0.0.0.255
access-list 3 permit xx.xx.xx.232
access-list 3 remark Auto generated by SDM Management Access feature
access-list 3 remark CCP_ACL Category=1
access-list 3 permit 192.168.0.0 0.0.0.255
access-list 100 remark Auto generated by SDM Management Access feature
access-list 100 remark CCP_ACL Category=1
access-list 100 permit tcp 192.168.0.0 0.0.0.255 host 192.168.0.1 eq telnet
access-list 100 permit tcp 192.168.0.0 0.0.0.255 host 192.168.0.1 eq 22
access-list 100 permit tcp 192.168.0.0 0.0.0.255 host 192.168.0.1 eq www
access-list 100 permit tcp 192.168.0.0 0.0.0.255 host 192.168.0.1 eq 443
access-list 100 permit tcp 192.168.0.0 0.0.0.255 host 192.168.0.1 eq cmd
access-list 100 permit udp 192.168.0.0 0.0.0.255 host 192.168.0.1 eq snmp
access-list 100 deny   tcp any host 192.168.0.1 eq telnet
access-list 100 deny   tcp any host 192.168.0.1 eq 22
access-list 100 deny   tcp any host 192.168.0.1 eq www
access-list 100 deny   tcp any host 192.168.0.1 eq 443
access-list 100 deny   tcp any host 192.168.0.1 eq cmd
access-list 100 deny   udp any host 192.168.0.1 eq snmp
access-list 100 permit ip any any
access-list 101 remark Auto generated by SDM Management Access feature
access-list 101 remark CCP_ACL Category=1
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
access-list 101 permit ip host xx.xx.xx.232 any
access-list 102 remark Auto generated by SDM Management Access feature
access-list 102 remark CCP_ACL Category=1
access-list 102 permit tcp host xx.xx.xx.232 host x.x.x.78 eq telnet
access-list 102 permit tcp host xx.xx.xx.232 host x.x.x.78 eq 22
access-list 102 permit tcp host xx.xx.xx.232 host x.x.x.78 eq www
access-list 102 permit tcp host xx.xx.xx.232 host x.x.x.78 eq 443
access-list 102 permit tcp host xx.xx.xx.232 host x.x.x.78 eq cmd
access-list 102 deny   tcp any host x.x.x.78 eq telnet
access-list 102 deny   tcp any host x.x.x.78 eq 22
access-list 102 deny   tcp any host x.x.x.78 eq www
access-list 102 deny   tcp any host x.x.x.78 eq 443
access-list 102 deny   tcp any host x.x.x.78 eq cmd
access-list 102 deny   udp any host x.x.x.78 eq snmp
access-list 102 permit ip any any
access-list 103 remark auto generated by CCP firewall configuration
access-list 103 remark CCP_ACL Category=1
access-list 103 permit tcp 192.168.0.0 0.0.0.255 host 192.168.0.1 eq telnet
access-list 103 permit tcp 192.168.0.0 0.0.0.255 host 192.168.0.1 eq 22
access-list 103 permit tcp 192.168.0.0 0.0.0.255 host 192.168.0.1 eq www
access-list 103 permit tcp 192.168.0.0 0.0.0.255 host 192.168.0.1 eq 443
access-list 103 permit tcp 192.168.0.0 0.0.0.255 host 192.168.0.1 eq cmd
access-list 103 deny   tcp any host 192.168.0.1 eq telnet
access-list 103 deny   tcp any host 192.168.0.1 eq 22
access-list 103 deny   tcp any host 192.168.0.1 eq www
access-list 103 deny   tcp any host 192.168.0.1 eq 443
access-list 103 deny   tcp any host 192.168.0.1 eq cmd
access-list 103 deny   udp any host 192.168.0.1 eq snmp
access-list 103 deny   ip x.x.x.72 0.0.0.7 any
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by CCP firewall configuration
access-list 104 remark CCP_ACL Category=1
access-list 104 permit tcp host xx.xx.xx.232 host x.x.x.78 eq telnet
access-list 104 permit tcp host xx.xx.xx.232 host x.x.x.78 eq 22
access-list 104 permit tcp host xx.xx.xx.232 host x.x.x.78 eq www
access-list 104 permit tcp host xx.xx.xx.232 host x.x.x.78 eq 443
access-list 104 permit tcp host xx.xx.xx.232 host x.x.x.78 eq cmd
access-list 104 deny   udp any host x.x.x.78 eq snmp
access-list 104 remark Custom Terminals
access-list 104 permit tcp any host x.x.x.73 range 1982 1984
access-list 104 remark Allow WebServer
access-list 104 permit tcp any host x.x.x.73 eq www
access-list 104 remark SVN Server
access-list 104 permit tcp any host x.x.x.73 eq 8443
access-list 104 remark From Rest To I7 All Port
access-list 104 permit ip host xx.xx.xx.232 host x.x.x.75
access-list 104 permit udp host 205.171.2.65 eq domain host x.x.x.78
access-list 104 permit udp host 205.171.3.65 eq domain host x.x.x.78
access-list 104 deny   ip 192.168.0.0 0.0.0.255 any
access-list 104 permit icmp any host x.x.x.78 echo-reply
access-list 104 permit icmp any host x.x.x.78 time-exceeded
access-list 104 permit icmp any host x.x.x.78 unreachable
access-list 104 permit tcp 192.168.0.0 0.0.0.255 host x.x.x.78 eq 4443
access-list 104 deny   ip 10.0.0.0 0.255.255.255 any
access-list 104 deny   ip 172.16.0.0 0.15.255.255 any
access-list 104 deny   ip 192.168.0.0 0.0.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 104 deny   ip host 0.0.0.0 any
access-list 104 deny   ip any any log
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username privilege 15 secret 0
Replace and with the username and password you
want to use.
^C
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
access-class 101 in
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
how to make a static NAT from x.x.x.73 to 192.168.0.2??
and if the computer with 192.168.0.2 access a URL what ip will the URL gets?? the x.x.x.73 or the ip with the router??
thank you very much!!
Here you go:
thank you for your help!
