1921 Router config for Cameras
jkay18041
Level 3
Level 3
I have a vendor who installed a camera system and assigned all the cameras and the NVR public IP addresses, needless to say it was hacked. I've purchased a 1921 router and am going to assign in the public IP and have it do NAT for the cameras and the NVR. Could someone please help me verify I've set it up right before I ship it.
I want to be able to access it remotely via ssh from 2 different places. an IP block of /26 and a single ip.
Also can you help me determine if I've setup NAT correctly and any other suggestions would be great.
I really appreciate the help.
Building configuration...
Current configuration : 1696 bytes
! Last configuration change at 13:49:47 UTC Mon Aug 20 2018
version 15.3
service password-encryption
hostname Camera_Router
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
ip dhcp excluded-address 192.168.50.1 192.168.50.50
ip dhcp pool Cameras
network 192.168.50.0 255.255.255.0
default-router 192.168.50.1
dns-server 8.8.8.8
lease 24
ip domain name slc1
ip cef
no ipv6 cef
license udi pid CISCO1921/K9 sn FTX18
username cotton privilege 15 password 7 091D6
redundancy
ip ssh version 2
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description WAN
ip address 11.203.126.3 255.255.255.128
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description LAN
ip address 192.168.50.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
interface Serial0/1/0
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list NAT interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 11.203.126.59
ip access-list extended NAT
permit ip any any
ip access-list extended SSH_ACCESS
permit ip 11.211.219.64 0.0.0.63 any
permit ip host 11.203.126.100 any
deny ip any any
control-plane
no vstack
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class SSH_ACCESS in
login local
transport input ssh
scheduler allocate 20000 1000
end
config looks good, the only thing I would change is the access list used for NAT:
version 15.3
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
dns-server 8.8.8.8
lease 24
ip domain name slc1
ip cef
no ipv6 cef
redundancy
ip ssh version 2
no ip address
shutdown
description WAN
ip nat outside
duplex auto
speed auto
description LAN
ip nat inside
duplex auto
speed auto
no ip address
shutdown
no ip address
shutdown
no ip http server
permit ip 192.168.50.0 0.0.0.255 any
deny ip any any
control-plane
no vstack
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login local
transport input ssh
end
version 15.3
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
dns-server 8.8.8.8
lease 24
ip domain name slc1
ip cef
no ipv6 cef
redundancy
ip ssh version 2
no ip address
shutdown
description WAN
ip nat outside
duplex auto
speed auto
description LAN
ip nat inside
duplex auto
speed auto
no ip address
shutdown
no ip address
shutdown
no ip http server
deny ip any any
control-plane
no vstack
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login local
transport input ssh
end
Great, thank you for the advice. I will get that changed.
