1921 Router w/4-PORT HWIC card
crixis
Is it possible to configure the HWIC ports as LAN ports? For example, i have the 1921 behind a consumer router so i know its a double NAT situation, its for a LAB, i want to be able to connect client devices on the 4 ports of the HWIC segregated from home network.
Is that possible? Do they need to be assigned IP addresses like a layer 3 port or can they be DHCP?
Thank you in advance
Joseph W. Doherty
Have you configured L3 switches?  If so, it's pretty much like that.
I believe (?) the router's SVI will support DHCP and NAT.  However, you may find the SVIs don't offer all the features the built-in router ports do.
6 Replies 6
Joseph W. Doherty
Unless you HWIC is L3 Ethernet, you'll need to use SVI(s), and VLAN(s).
Can I configure 1 or 2 vlans or do they have to each have separate vlans? But no setup with DHCP and an IP helper similar to a router on a stick setup.
Joseph W. Doherty
Ok thanks
I have very little experience with L3 switches.
Appreciate your time
Ok, in Packet Tracer, I selected a 1941 (as it doesn't offer the 1921, and the 1941 is just the more "powerful" model.
I then installed a HWIC-4ESW in the first
         --- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
%LINK-5-CHANGED: Interface FastEthernet0/1/0, changed state to up
%LINK-5-CHANGED: Interface FastEthernet0/1/1, changed state to up
%LINK-5-CHANGED: Interface FastEthernet0/1/2, changed state to up
%LINK-5-CHANGED: Interface FastEthernet0/1/3, changed state to up
Press RETURN to get started!
model slot, and booted the router.
During boot up, we "see" the 4 module ports:
To use much like a router port, you assign a VLAN to one of those ports and then assign a SVI:
Router>en
Router#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#int f0/1/0
Router(config-if)#sw
Router(config-if)#switchport access vlan 2
% Access VLAN does not exist. Creating vlan 2
Router(config-if)#int vlan 2
Router(config-if)#
%LINK-5-CHANGED: Interface Vlan2, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan2, changed state to up
Router(config-if)#ip address 192.168.1.1 255.255.255.0
Router(config-if)#end
Router#
interface FastEthernet0/1/0
 switchport mode access
interface Vlan2
 mac-address 00d0.bc42.d701
Joseph,
Thanks, that is helpful to see, and gives me a direction to go in, Appreciate that.
Best Regards.
