1921 with only 15Mbps bandwidth?
fortissimo2015
I need a router 1921/K9 and checked its datasheet,
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps7290/ps10589/data_sheet_c78-598389.html
noticed words:
The Cisco 1900 Series enables deployment in high-speed WAN environments with concurrent services enabled up to 15 Mbps.
It's a damn low number that I can't believe my eyes. Is it real?
daniel.dib
Level 7
Level 7
That is a recommendation for when you should select the 1921. It's not the maximum speed it can handle. Check this document:
http://anticisco.ru/pubs/ISR_G2_Perfomance.pdf
In that test the 1921 performed 68 Mbps with NAT and QoS. Without advanced features it can perform more but with even more features it could perform less. That's why it's a recommendation to use it for 15 Mbps circuits. So you always have to look at these numbers and your deployment scenario and then choose a properly sized router.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
15 Mbps (duplex) is (or very much was) considered high speed for WANs.  Remember WAN links were high speed when they exceed a T1's or E1's bandwidth. Also note, DSL or cable modems doesn't often exceed 10 Mbps.  (Note - today, cable modems might offer 20 to 100 Mbps.)
Cisco's performance recommendations are very conservative, they try to insure you won't overtax the CPU regardless of your configuration assuming the bandwidth consumption is continuous at the maximum recommended bandwidth.
