1941 Dual Wan + Nat + VPN
secon-asc
i've got some issues with a router Config.
We've two PPPoE WAn Connectios with static IP.
normal Internet Access with Nat should go through DSL-1 (failover to DSL-2)
Static Nat (Port Forward) and our RAS-VPN should work on both external IP's.
2 Site-to-Site VPNs should go on DSL-2 (Failover to DSL-1)
here my Config so far:
version 15.1
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa group server radius sdm-vpn-server-group-1
server 192.168.100.5 auth-port 1645 acct-port 1646
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 group sdm-vpn-server-group-1 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa authorization network ciscocp_vpn_group_ml_2 local
aaa session-id common
clock timezone Berlin 1 0
clock summer-time Berlin date Mar 30 2003 2:00 Oct 26 2003 3:00
no ipv6 cef
ip source-route
ip cef
ip domain name xxxxxx.de
ip name-server 8.8.8.8
ip name-server 8.8.4.4
redundancy
ip scp server enable
track 1 ip sla 1
delay down 5 up 2
track 2 ip sla 2
delay down 5 up 2
crypto isakmp policy 1
encr aes 256
hash sha512
authentication pre-share
group 16
crypto isakmp policy 2
encr aes 256
group 2
crypto isakmp key dummy address Site1-IP
crypto isakmp xauth timeout 10
crypto isakmp client configuration group RAS_VPN_1
key udfgdfg
pool SDM_POOL_1
acl 150
max-users 30
netmask 255.255.255.192
crypto isakmp client configuration group RAS_VPN_2
key asdfasdfsdf
pool SDM_POOL_2
acl 151
max-users 30
crypto isakmp profile ciscocp-ike-profile-1
   match identity group RAS_VPN_1
   client authentication list ciscocp_vpn_xauth_ml_1
   isakmp authorization list ciscocp_vpn_group_ml_1
   client configuration address respond
   virtual-template 1
crypto isakmp profile ciscocp-ike-profile-2
   match identity group RAS_VPN_2
   isakmp authorization list ciscocp_vpn_group_ml_2
   virtual-template 2
crypto ipsec transform-set RAS_VPN esp-aes 256 esp-sha-hmac
crypto ipsec profile CiscoCP_Profile1
description RAS VPN 1
set security-association idle-time 3600
set transform-set RAS_VPN
set isakmp-profile ciscocp-ike-profile-1
crypto ipsec profile CiscoCP_Profile2
description RAS VPN 2
set isakmp-profile ciscocp-ike-profile-2
!---VPN: Site-to-Site
crypto ipsec transform-set VPN esp-aes 256 esp-sha512-hmac
crypto map D1_Site 10 ipsec-isakmp
set peer Site1_ip
set transform-set VPN
match address VPN_1
crypto map D1_Site 20 ipsec-isakmp
set peer Site1_ip
match address VPN_2
!--- Inerface Configuration
interface Loopback0
ip address 192.168.230.1 255.255.255.192
interface Loopback1
ip address 172.20.230.1 255.255.255.192
interface GigabitEthernet0/0
description green
no ip address
ip virtual-reassembly in
ip tcp adjust-mss 1412
duplex auto
speed auto
interface GigabitEthernet0/0.1
description LAN
encapsulation dot1Q 2 native
ip address 192.168.100.2 255.255.255.0
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat inside
ip policy route-map PBR
interface GigabitEthernet0/1
description WI orange
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
description LAN 2
encapsulation dot1Q 1 native
ip address 172.20.100.2 255.255.255.0
ip flow ingress
ip flow egress
interface FastEthernet0/0/0
description DSL-1
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface FastEthernet0/0/1
description DSL-2
no ip address
duplex auto
speed auto
pppoe-client dial-pool-number 2
interface Virtual-Template1 type tunnel
description RAS-VPN 1
ip unnumbered Loopback0
tunnel mode ipsec ipv4
tunnel protection ipsec profile CiscoCP_Profile1
interface Virtual-Template2 type tunnel
description RAS-VPN 2
ip unnumbered Loopback1
tunnel protection ipsec profile CiscoCP_Profile2
interface Dialer1
description DSL-1 (VDSL)
ip address negotiated
ip mtu 1452
ip flow ingress
ip flow egress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxx
ppp chap password 0 xxx
ppp pap sent-username xxx password 0 xxx
crypto map D1_Site
interface Dialer2
description DSL-2 (T-DSL)
ip mtu 1452
ip flow ingress
ip flow egress
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
crypto map D1_Site
ip local pool SDM_POOL_1 192.168.230.34 192.168.230.62
ip local pool SDM_POOL_2 172.20.230.34 172.20.230.62
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http secure-port 10443
ip http timeout-policy idle 60 life 86400 requests 10000
!--- DNS Server
ip dns server
!--- NAT
ip nat inside source route-map NAT_DSL-1 interface Dialer1 overload
ip nat inside source route-map NAT_DSL-2 interface Dialer2 overload
!--- NAT Access-Lists
access-list 100 remark -= Outgoing NAT -> DSL-1 =-
access-list 100 deny   ip 192.168.100.0 0.0.0.255 192.168.40.0 0.0.0.255
access-list 100 permit ip 192.168.100.0 0.0.0.255 any
access-list 101 remark -= Outgoing NAT -> DSL-2 =-
access-list 101 deny   ip 192.168.100.0 0.0.0.255 192.168.40.0 0.0.0.255
access-list 101 permit ip 192.168.100.0 0.0.0.255 any
!--- Policy-Based-Routing Access-List
access-list 110 remark -= PBR 1 =-
access-list 110 permit ip 192.168.100.0 0.0.0.255 any
!--- Routing
ip route 0.0.0.0 0.0.0.0 Dialer2 track 2
ip route 0.0.0.0 0.0.0.0 Dialer1 track 1
!--- VPN Access-Lists
ip access-list extended VPN_1
permit ip 192.168.100.0 0.0.0.255 192.168.40.0 0.0.0.255
ip access-list extended VPN_2
permit ip 172.20.100.0 0.0.0.255 172.20.110.0 0.0.0.255
access-list 150 remark -= RAS VPN 1 =-
access-list 150 remark CCP_ACL Category=4
access-list 150 permit ip 192.168.100.0 0.0.0.255 any
access-list 151 remark -= RAS VPN 2 =-
access-list 151 remark CCP_ACL Category=4
access-list 151 permit ip 172.20.100.0 0.0.0.255 any
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
!--- Route Maps
route-map NAT_DSL-1 permit
match ip address 100
match interface Dialer1
route-map NAT_DSL-2 permit
match ip address 101
match interface Dialer2
route-map PBR permit 10
match ip address 110
set interface Dialer 1
route-map PBR permit 20
set interface Dialer 2
ip radius source-interface GigabitEthernet0/0.1
ip sla 1
icmp-echo Dialer1_ip
tag Check DSL-1
threshold 300
timeout 500
frequency 5
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo Dialer2_ip
tag Check DSL-2
threshold 300
timeout 500
frequency 1
ip sla schedule 2 life forever start-time now
radius-server host 192.168.100.5 auth-port 1645 acct-port 1646 timeout 10 key xxxxx
end
my problems start very early, sometimes i'm not able to ping anything outside.. have you got some suggestions for me?
0 Replies 0
