Bookmark
Subscribe
721
Testing 2
michaelriccioni
test
cadet alain
without adding the static route on the 10.10.10.10 server , could you show us its routing table to verify it has the ASA as default gateway. if so then on the ASA could you do a packet-tracer command like this:
packet-tracer input Inside tcp 10.10.10.10 2000 10.10.13.10 53 detailed
Post the output here.
Regards.
Alain
Try adding static routes to the 888's for routes to the 10.10.10.0/24 and 10.10.13.0/24 networks from the respective routers.
I can't explain why the routing doesn't work when you just rely on the default routes to handle the traffic, but I have seen this before.
Kind regards,
Paul
HTH Paul ****Please rate useful posts****
