1941 problem with ESW and ESG
MattNaidar
Hi Forums,
I have an issue that I'm hoping someone can shed a little light on.
I have a 1941 with recent version 15.2-2T IOS happily working with a HWIC-4ESG (4 port Gig) card located in slot 1. When I add a HWIC-4ESW (4 port 100Mb/s) in slot0, then the gig card in slot 1 is no longer seen - it just dissappears (almost as though it's using the same memory location which I believe it is).
I've tried swapping them over. It seems as though whatever is in slot 0 takes preference. They both work on their own, in either slot, but only on their own. When they are in there together, only the switch card in slot 0 works.
I will try upgrading tomorrow to see if this helps.
Has anyone seen this before or can assist?
I've gone through bug toolkit, couldn't find anything about it.
Thanking you in advance.
Cheers,
Matt
I've found out that the 4 and 9 port HWIC switchport cards don't with EHWICs. :(
MattNaidar
Rather than wait for tomorrow, I've upgraded and done further tests tonight.
Show ver
c1941-home uptime is 1 minute
System image file is "flash0:c1900-universalk9-mz.SPA.155-2.T.bin"
Last reload type: Normal Reload
Last reload reason: power-on
partial boot messages
Smart Init is enabled
smart init is sizing iomem
TYPE MEMORY_REQ
HWIC Slot 0 0x00200000
HWIC Slot 1 0x00200000
Onboard devices &
buffer pools 0x01E8F000
TOTAL: 0x0228F000
Cisco CISCO1941/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID FGL15342135
4 FastEthernet interfaces
2 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
62720K bytes of ATA CompactFlash 1 (Read/Write)
show int desc shows slot 1 4x Gig interfaces gone
Interface Status Protocol Description
Em0/0 admin down down
Gi0/0 up up
Gi0/1 up up
Gi0/1.1 up up
Gi0/1.200 up up
Fa0/0/0 down down
Fa0/0/1 down down
Fa0/0/2 down down
Fa0/0/3 down down
BV200 up up
show inventory shows no sign either
PID: CISCO1941/K9 , VID: V02 , SN: CCCCCCC
NAME: "4 Port FE Switch on Slot 0 SubSlot 0", DESCR: "4 Port FE Switch"
PID: HWIC-4ESW , VID: VN/A, SN: CCCCCCC
NAME: "C1941/C2901 AC Power Supply", DESCR: "C1941/C2901 AC Power Supply"
PID: PWR-1941-2901-AC , VID: , SN: CCCCCC
Then you turn it off, unplug the ESW, and the ESG re-appears!
show inventory
NAME: "4 Port GE Non-POE EHWIC Switch on Slot 0 SubSlot 1", DESCR: "4 Port GE Non-POE EHWIC Switch"
PID: EHWIC-4ESG , VID: V01 , SN: CCCCC
To reply a third time to myself!, normally the gig switchcard is located in slot 1 and an ATM card in slot 0, both fully functional at the same time - never had an issue. I got off ATM today and needed a couple of extra ports. So it really does seem that when 2 switch cards of differing speeds are used similtaneously.
I should mention this is mixing EHWIC with HWIC.
