Control RT for different network in MPLS
wfqk
Level 5
Level 5
Hi We know RT in MPLS controls network traffic. Can we say as long as two RT in two PE are same(import/export), the customer behind the PE can reach each other? Do we still need other condition? Thank you.
2 Accepted Solutions
Harold Ritter
Yes, that is correct. As long as the exported RT extended community on the sending PE is matched by the import RT value on the receiving PE, the information is imported on this same PE. The export value on both PE does not need to match. Neither does the import value.
Julio E. Moisa
As Harold mentioned, You can have the same RT (export/import) on each PE or the export can be different, The condition is that they should be over the same VRF.
For example:
PE01
ip vrf A
route-target export 1:100
route-target import 2:200
PE02
ip vrf A
route-target export 2:200
route-target import 1:100
Both PE's are exporting through differents export communities but they are importing the community from each other.  You could use the same RT communities (import/export) on both sides  to keep an order.
PE01
ip vrf A
PE02
ip vrf A
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Harold Ritter
Julio E. Moisa
For example:
PE01
ip vrf A
PE02
ip vrf A
PE01
ip vrf A
PE02
ip vrf A
