Pesistent Logging Configuration
Cisco Freak
Level 4
Level 4
I am encountering this error when setting up persistent logging.
switch(config)#logging persistent url ?
disk0: Filesystem name
slavedisk0: Filesystem name
slavesup-bootdisk: Filesystem name
slavesup-bootflash: Filesystem name
sw1-slot5-disk0: Filesystem name
sw1-slot5-sup-bootdisk: Filesystem name
sw1-slot5-sup-bootflash: Filesystem name
sw2-slot5-disk0: Filesystem name
sw2-slot5-sup-bootdisk: Filesystem name
sw2-slot5-sup-bootflash: Filesystem name
switch(config)#logging persistent url sup-bootdisk:Log
%No "disk0:/sup-bootdisk:Log" installed
Is there a restriction that persistent log can be configured only to disk0?
CF
9 Replies 9
Julio E. Moisa
Try with
logging persistent url sup-bootdisk:/Log
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
It didn't work.
switch(config)#logging persistent url sup-bootdisk:/Log
%No "disk0:/sup-bootdisk:/Log" installed
Do you see something on that location?
show sup-bootdisk:
or try using the sup-bootflash:
Again no luck!
show sup-bootdisk and show sup-bootflash list the contents there successfully.
switch(config)#logging persistent url sup-bootflash:/Log
%No "disk0:/sup-bootflash:/Log" installed
switch(config)#logging persistent url sup-bootflash:Log
%No "disk0:/sup-bootflash:Log" installed
Any help would be appreciated!
on a side note, did you configure 'logging buffered' before entering the persistent commands ?
I did. The device is running buffered logging and remote syslog as well.
what is your IOS?
it might be that your platform (which is your platform ?) does not allow writing to sup. Does the below work ?
logging persistent url disk0:/syslog size 134217728 filesize 16384
