1941 Throughput/routing
Patrick Beaven
I've got an oppurtunity to use several smaller routers in wan scenario. In the past Ive always used the 1841 router to run these smaller sites.
10-20Mbps. Does anyone have any opinion on using 1941 with OSPF and using both ethernet interfaces?
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
The 1941 is rated at about 4x the PPS rate fo the 1841. Its 299 Kbps should easily handle a pair of Ethernet interfaces and would likely do well with a pair of FastEtherenet interfaces, unless the latter were fully saturated with minimum sized packets.
