1GBit + BGP - Need help choosing router
secretAlpaca
Hello, I am about to register an ASN and buy a /24 public range so I can own multiple IP addresses, as my ISP asks for 35$ for one IP..
I own a Cisco 1921 ISR that allows me 250mbit and bgp, and I wanted to be able to use a router capable of 1gbit speed and use the bgp function to point to my range to that range i'll buy,
So my ISP agrees with replacing the ONT/router with a regular ONT non-routed Ethernet port, so I wanted to know what router should I go with?
Thanks in advance
not sure what you mean bynon-routed Ethernet port...
Either way, the ISR 4331 or the ASR 1001-X would be a good choice for a replacement...
ISR 4331
https://www.cisco.com/c/en/us/products/routers/router-comparison.html?product_id=41|42|43|44|45|46|57
ASR 1000
https://www.cisco.com/c/en/us/products/routers/asr-1000-series-aggregation-services-routers/models-comparison.html
ISR 4331
ASR 1000
