%SYS-2-BADSHARE: Bad refcount in datagram_done
after upgrading to IOS version: 16.9.3s  on our Catalyst 9300's used in conjunction with with DNA center, we are seeing the following errors:
Jul 17 10:13:07.188: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=80007FF893861CF8, count=0
-Traceback= 1#f1c4474ae48ba7cfcc7f4393795f7efb :55CA8B41C000+43306BB iosd_shr_m_uk9_IPV6_Core_crb:7FF9836EF000+3D6E9B iosd_shr_m_uk9_IPV6_Core_crb:7FF9836EF000+3D5449 iosd_shr_m_uk9_IPV6_Core_crb:7FF9836EF000+37DA63 iosd_shr_m_uk9_IPV6_Core_crb:7FF9836EF000+37AC5F iosd_shr_m_uk9_IPV6_Core_crb:7FF9836EF000+3B5672 :55CA8B41C000+68A00AD iosd_shr_m_uk9_IPV6_Core_crb:7FF9836EF000+3B46D2 :55CA8B41C000+6875C36
Anyone else seeing similar errors?
-Mike
6 Replies 6
balaji.bandi
Looks liek bug for me and cisco had fixed the version you mentioned as per the document, suggest to contact TAC, if any service outage.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvq30460
BB
dm2020
I have been receiving the same errors. Did you find a solution to this?
Do you have smartnet contract to raise an TAC case ?
BB
I do and I will raise a case but wanted to check if the original poster managed to resolve this issue or if its cosmetic and not actually service impacting.
We are running IOS-XE 16.9.3s which is Cisco's recommended release for SD-Access (specially built code version I believe) which is working well except for this error so hoping there is no need to upgrade.
No we have not found a reason for this but it also has not impacted our production environment for us. Other searches have proven that this might be a bug related to DHCP snooping. Even though we have access to open a TAC case we chose not to.
We are also running Cisco’s preferred software version on our core, distribution and edge switches.
Great, thanks for the reply. Much appreciated
