2 company share 1 network
farozezan73
My company A has a big network with 109 nos (site office) of 3750e and every switches has a 6 vlan. Recently our sister company B submit a proposal & intent to share the network. My question is how to make this happen as we are very concern about the security. I've plan to create a new vlan for company B in every switches but how to restrict the access? Note : both company has own internet access. company A ip is 10.74.x.x and co B 10.1.x.x
tq
Jon Marshall
tq
Have a read of this recent thread and them come back if you have further questions -
https://supportforums.cisco.com/thread/2039816?tstart=30
I would not recommend having vlans for each company on all your switches. The other company can simply route to your vlans and vice-versa but you do need to think about firewalls.
Jon
Nagaraja Thanthry
If you do not want Company B to access company A and vice versa, put
access-lists on the core router (router that handles routing between vlans).
The access-list should look like:
access-list 101 deny ip 10.74.0.0 0.0.255.255 10.1.0.0 0.0.255.255
access-list 101 deny ip 10.1.0.0 0.0.255.255 10.74.0.0 0.0.255.255
interface vlan "vlan id"
ip access-group 101 in
exit
This will prevent all communication between Company A vlans and Company B
vlan. If you want specific traffic to flow between them, then you need to
insert those rules before the deny rules.
access-list 101 permit tcp any any eq www
access-list 101 permit tcp any any eq https
access-list 101 permit tcp any eq www any
access-list 101 permit tcp any eq https any
Above configuration allows HTTP and HTTPS traffic between two networks.
Hope this helps.
NT
Tq for your reply. One more thing, the existing network use eigrp protocol. Should I use static route for the new network or eigrp? For info the new network use only 15 routers. tq
Per Tenggren
Separate the companies with different VRFs.
