2 DMVPN Tunnels via separate ISP on one spoke
Marley Brown
I am trying to setup a backup DMVPN tunnel at a spoke site. When I so a sh DMVPN on the hub side I get the following I can ping across tunnel0 but not tunnel1.
Tunnel0, Type:Hub, NHRP Peers:2,
 # Ent  Peer NBMA Addr Peer Tunnel Add State  UpDn Tm Attrb
     2    x.x.x.153      11.11.11.2    UP    never D
Tunnel1, Type:Hub, NHRP Peers:1,
     1    x.x.x.154      11.11.12.2    UP    never DN
The primary tunnel show the IP assigned from ISP1 and the back tunnel is the gateway from ISP1
sh ip hnrp on the hub: x.x.x->ISP1 y.y.y->ISP2
11.11.12.2/32 via 11.11.12.2, Tunnel1 created 00:07:34, expire 00:05:28
  Type: dynamic, Flags: registered used
  NBMA address: x.x.x.154
    (Claimed NBMA address: y.y.y.185)\
any help would appreciated,
M
23 Replies 23
post the configs of the hub and the spoke...
Georg,
Sorry for the delayed response. Here the configs for the hub and spoke.
When I take the protection off the tunnel1 I get the original post and no connection with protection I get nhrp as the status under sh DMVPN
thanks,
M
HUB
hostname A&M-_RT
spanning-tree portfast bpduguard
crypto keyring ccp-dmvpn-keyring
  pre-shared-key address 0.0.0.0 0.0.0.0 key Private
crypto isakmp policy 1
 encr 3des
 authentication pre-share
 group 2
crypto isakmp client configuration group ansbacher
 key ansbachersti01x
 dns 10.4.1.12
 wins 10.4.1.12
 pool SDM_POOL_1
 acl 100
crypto isakmp client configuration group ansbacher1
 key Private
 dns 10.4.1.10
 pool SDM_POOL_1
 acl 106
crypto isakmp profile sdm-ike-profile-1
   match identity group ansbacher
   client authentication list sdm_vpn_xauth_ml_1
   isakmp authorization list sdm_vpn_group_ml_1
   client configuration address respond
   virtual-template 1
crypto isakmp profile ciscocp-ike-profile-1
   match identity group ansbacher1
   virtual-template 2
crypto isakmp profile ccp-dmvpn-isakmprofile
   match identity address 0.0.0.0
   qos-group 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA2 esp-3des esp-sha-hmac
 mode transport
crypto ipsec profile CiscoCP_Profile1
 set transform-set ESP-3DES-SHA1
 set isakmp-profile ciscocp-ike-profile-1
crypto ipsec profile CiscoCP_Profile2
 set transform-set ESP-3DES-SHA2
 set isakmp-profile ccp-dmvpn-isakmprofile
crypto ipsec profile SDM_Profile1
 set security-association idle-time 7200
 set isakmp-profile sdm-ike-profile-1
crypto ctcp port 10000 11000 12000
archive
 log config
  hidekeys
interface Tunnel0
 description $FW_INSIDE$
 bandwidth 100000
 ip address 11.11.11.1 255.255.255.0
 no ip redirects
 ip mtu 1400
 no ip next-hop-self eigrp 100
 ip nhrp authentication DMVPN_NW
 ip nhrp map multicast dynamic
 ip nhrp network-id 100000
 ip nhrp holdtime 360
 no ip route-cache cef
 ip tcp adjust-mss 1440
 no ip split-horizon eigrp 100
 no clns route-cache
 tunnel source FastEthernet0
 tunnel mode gre multipoint
 tunnel key 100000
 tunnel protection ipsec profile CiscoCP_Profile2
interface Tunnel1
 description BACKUP
 bandwidth 24000
 ip address 11.11.12.1 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp network-id 2
 ip tcp adjust-mss 1400
 delay 1001
 no clns route-cache
 tunnel key 2
interface FastEthernet0
 description COMCAST FIBER
 ip address x.x.x.163 255.255.255.248
 ip verify unicast reverse-path
 ip inspect CCP_LOW out
 ip virtual-reassembly
 duplex auto
 speed auto
interface FastEthernet1
 description $FW_OUTSIDE$
 ip address y.y.y.125 255.255.255.248
 ip access-group 112 in
 ip nat outside
 duplex auto
 speed auto
interface FastEthernet9
interface Virtual-Template1 type tunnel
 ip unnumbered FastEthernet1
 ip access-group 108 in
 tunnel mode ipsec ipv4
 tunnel protection ipsec profile SDM_Profile1
interface Virtual-Template2 type tunnel
 ip access-group 109 in
 tunnel protection ipsec profile CiscoCP_Profile1
interface Vlan1
 description $ETH-SW-LAUNCH$$INTF-INFO-FE 2$$ES_LAN$$FW_INSIDE$
 ip address 100.10.10.2 255.255.255.0
 ip tcp adjust-mss 1412
i
router eigrp 100
 redistribute static
 network 11.11.11.0 0.0.0.255
 network 11.11.12.0 0.0.0.255
 no auto-summary
 neighbor 11.11.11.3 Tunnel0
 neighbor 11.11.11.2 Tunnel0
 neighbor 11.11.12.2 Tunnel1
ip local pool SDM_POOL_1 192.168.50.1 192.168.50.50
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 50.235.49.161
ip route 10.4.1.0 255.255.255.0 100.10.10.1
ip route 10.5.1.0 255.255.255.0 11.11.11.2
ip route 10.6.1.0 255.255.255.0 11.11.11.3
ip route 10.7.1.0 255.255.255.0 11.11.11.4
ip route 172.20.2.0 255.255.255.0 11.11.11.3
ip route 192.168.10.0 255.255.255.0 11.11.11.3
ip route 192.168.12.0 255.255.255.0 11.11.11.2
ip route 192.168.12.0 255.255.255.0 11.11.12.2 200
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool comcast x.x.x.125 173.165.198.125 netmask 255.255.255.248
SPOKE
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
ip cef
no ip domain lookup
no ipv6 cef
crypto keyring ccp-dmvpn1-keyring
  pre-shared-key address 0.0.0.0 0.0.0.0 key private
 encr 3des
 group 2
crypto isakmp key private address x.x.x.163
crypto isakmp keepalive 30 5
 key ansbachersti01x
 pool SDM_POOL_1
 acl 100
   client authentication list ciscocp_vpn_xauth_ml_1
   isakmp authorization list ciscocp_vpn_group_ml_1
   virtual-template 1
 mode transport
 mode transport
 set security-association idle-time 3600
 class class-default
interface Tunnel0
 bandwidth 200000
 ip address 11.11.11.2 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp map 11.11.11.1 50.235.49.163
 ip nhrp map multicast 50.235.49.163
 ip nhrp nhs 11.11.11.1
 ip nhrp registration no-unique
 tunnel key 100000
interface Tunnel1
 bandwidth 24000
 ip address 11.11.12.2 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp map 11.11.12.1 50.235.49.163
 ip nhrp nhs 11.11.12.1
 delay 1001
 tunnel source FastEthernet1
 tunnel key 2
 description $ETH-WAN$
 ip address y.y.y.153 255.255.255.248
 ip nbar protocol-discovery
 ip nat outside
 ip policy route-map tunnel0
 duplex auto
 speed auto
 service-policy output CCP-QoS-Policy-1
 ip address z.z.z.185 255.255.255.248
 ip nat outside
 ip policy route-map tunnel1
 duplex auto
 speed auto
 ip unnumbered FastEthernet0
interface Vlan1
 ip address 10.5.1.1 255.255.255.0
 ip helper-address 10.4.1.12
 ip nat inside
 ip tcp adjust-mss 1452
interface Vlan10
 ip address 192.168.12.1 255.255.255.0
 ip nat inside
router eigrp 100
 redistribute static
 network 10.5.1.0 0.0.0.255
 no auto-summary
 neighbor 11.11.11.1 Tunnel0
 neighbor 11.11.12.1 Tunnel1
ip local pool SDM_POOL_1 172.20.2.1 172.20.2.10
ip route 0.0.0.0 0.0.0.0 96.94.49.154
ip route 0.0.0.0 0.0.0.0 99.14.166.190 20
ip http server
ip flow-top-talkers
 top 10
 sort-by bytes
ip nat inside source static tcp 10.5.1.253 8000 interface FastEthernet0 8000
ip nat inside source static tcp 10.5.1.253 8554 interface FastEthernet0 8554
ip nat inside source route-map att interface FastEthernet1 overload
ip nat inside source route-map comcast interface FastEthernet0 overload
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.5.1.0 0.0.0.255
access-list 1 permit 192.168.12.0 0.0.0.255
access-list 2 permit 11.11.11.0 0.0.0.255
access-list 3 permit 11.11.12.0 0.0.0.255
access-list 100 remark CCP_ACL Category=4
access-list 100 permit ip 10.4.1.0 0.0.0.255 any
access-list 100 permit ip 10.5.1.0 0.0.0.255 any
access-list 110 remark CCP_ACL Category=256
access-list 110 permit udp any any range 6000 6036
no cdp run
route-map 10 permit 10
route-map tunnel0 permit 10
 match ip address 2
 match interface FastEthernet0
 set ip next-hop 99.14.166.190
route-map tunnel1 permit 10
 match ip address 3
 match interface FastEthernet1
 set ip next-hop 99.14.166.160
route-map att permit 10
 match ip address 1
route-map comcast permit 10
 match ip address 1
you have the same IPSec profile configured for both tunnel interfaces. Try and add the keyword 'shared':
tunnel protection ipsec profile CiscoCP_Profile2 shared
to all the tunnel protection configuration lines.
Both tunnels came up and tunnel1 was the primary. I want tunnel0 to be primary. When I did a shut/no shut on tunnle1 both tunnels are stuck on IKE at the sh DMVPM
This the sh dmvpn on the hub
Interface: Tunnel0, IPv4 NHRP Details
     2         0.0.0.0      11.11.11.2  NHRP    never    IX
     0         0.0.0.0      11.11.11.4  NHRP    never    IX
     1   x.x.x.x      11.11.11.3    UP 18:54:10     D
Interface: Tunnel1, IPv4 NHRP Details
Type:Unknown, NHRP Peers:1,
     1         0.0.0.0      11.11.12.2  NHRP    never    IX
I am labbing this in GNS3...what are the IP addresses of the FastEthernet interfaces ?
 spoke
int f0
 ip address 96.94.49.153 255.255.255.248
int f1
ip address 99.14.166.185 255.255.255.248
hub
 int f0
ip address 50.235.49.163 255.255.255.248
try and add:
ip nhrp redirect
and
ip nhrp shortcut
on both sides (hub and spoke).
Georg,
With just those commands it did not work. I did do a shut/no shut on tunnel1 on the spoke and that brought the tunnel up.
Also how do I control the nhrp tunnel check time? After I shut inf f0 on the spoke the hub still showed tunnel0 and 1 as up even though they were not.
try and set the isakmp keepalive on both ends:
crypto isakmp keepalive 10 5
Still not working, tunnel1 is not stable. a lot of int tunnel shut/no shut to get going.
M
can you remove:
from the hub configuration ? Since your advertised networks include the tunnels, the neighbor statements are unnecessary. They cause unicast traffic to flow between the neighbors, I am not sure what effect that has...
I am back to tunnel1 doesn't connect. I have removed all the changes after the post were you posted config with modifications trying to get back to were tunnels connected. I did remove the neighbor statement from eirgp.
Also if shut down any of the tunnels both reset. and I shut/no shut tunnel1 tunnle0 resets and doesn't connect until I do a shut/no shut on tunnel0.
M
Marley,
your config has multiple other parameters on top of the basic DMVPN tunnel setup. What IOS version are you running ? I can check for bugs, that's always a possibility...
