2 ISP + NAT (some DHCP, some static)
artursanet
Hi I have two ISP:
ISP 1  - 10.11.12.1 255.255.255.240
ISP 2 -  20.21.22.1 255.255.255.248
I have LAN:
192.168.100.1 255.255.255.0
there are 3 server inside with static NAT address with ISP 1:
192.168.100.10 (10.11.12.4)
192.168.100.20 (10.11.12.5)
192.168.100.30 (10.11.12.6)
and the rest NAT is DHCP from 192.168.100.51 with overload IP with ISP 2:
20.21.22.5
Now I want to make it that all the server (static IP) go through ISP 1 and all DHCP clients go trought ISP 2.
Please help me with that.
Can i do it with "ip route" command?
I thought that it should be okay if I have two entries like that:
ip route 0.0.0.0 0.0.0.0  10.11.12.1
ip route 0.0.0.0 0.0.0.0  20.21.22.1
but this does not work. Everything goes trough 10.11.12.1.
artursanet
how it should be
Hello
As your router will have connected interfaces to these ISPs , You shouldn't have to use two default statics just the primary would be required with an addition of a PBR rule however please note applying statics in this way without any king of conditional rule would not give you any resiliency if the primary ISP became unavailable.
Note: the resiliency can be accomplished by utilising IP Sla and Object tracking (not shown)
Please review below..
ip nat inside source list 1 interface <ISP1> overload
ip nat inside source list 2 interface <ISP2> overload
ip nat inside source static 192.168.100.10 10.11.12.4
ip nat inside source static 192.168.100.20 10.11.12.5
ip nat inside source static 192.168.100.30 10.11.12.6
access-list 1 permit host192.168.100.10
access-list 1 permit host 192.168.100.20
access-list 1 permit host 192.168.100.30
access-list 2 deny  host 192.168.100.10
access-list 2 deny  host  192.168.100.20
access-list 2 deny  host  192.168.100.30
access-list 2 permit 192.168.100.0 0.0.0.255
route-map STAN permit 20
match ip address 1
set ip next-hop 10.11.12.1
int xx
description Lan facing
ip nat inside
ip policy route-map STAN
int xx
description ISP1
ip nat outside
int xx
description ISP2
ip nat outside
ip route 0.0.0.0 0.0.0.0 <iinterface isp2) 20.21.22.1
res
Paul
Kind Regards
Paul
