dmvpn backup tunnel for physical interface isp failover not connecting
Marley Brown
I have a 2 spoke to hub  DMVPN setup, we are working on getting one spoke setup with 2 ISP's on 2 physical interfaces. I have everything working except the backup tunnel will not connect. I have researched this and followed some examples, but can't get it to work. The back up tunnel seem to flop.
Here are the config for the hub and spoke.
M
HUB
interface Tunnel0
 description Primary tunnel
 bandwidth 100000
 ip address 11.11.11.1 255.255.255.0
 no ip redirects
 ip mtu 1400
 no ip next-hop-self eigrp 100
 ip nhrp authentication DMVPN_NW
 ip nhrp map multicast dynamic
 ip nhrp network-id 100000
 ip nhrp holdtime 360
 no ip route-cache cef
 ip tcp adjust-mss 1440
 no ip split-horizon eigrp 100
 no clns route-cache
 tunnel source FastEthernet0
 tunnel mode gre multipoint
 tunnel key 100000
 tunnel protection ipsec profile CiscoCP_Profile2
interface Tunnel1
 description backup tunnel
 bandwidth 100000
 ip address 11.11.12.1 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp network-id 2
 ip tcp adjust-mss 1400
 delay 1001
 no clns route-cache
 tunnel key 2
interface FastEthernet0
 description  FIBER
 ip address x.x.x.163 255.255.255.248
 ip verify unicast reverse-path
 ip inspect CCP_LOW out
 ip virtual-reassembly
 duplex auto
 speed auto
router eigrp 100
 redistribute static
 network 10.4.1.0 0.0.0.255
 network 11.11.11.0 0.0.0.255
 network 11.11.12.0 0.0.0.255
 no auto-summary
 neighbor 11.11.11.2 Tunnel0
 neighbor 11.11.11.3 Tunnel0
 neighbor 11.11.12.2 Tunnel1
ip route 0.0.0.0 0.0.0.0 x.x.x.161
SPOKE
interface Tunnel0
 description primary tunnel
 bandwidth 200000
 ip address 11.11.11.2 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp map 11.11.11.1 x.x.x.163
 ip nhrp map multicast x.x.x.163
 ip nhrp nhs 11.11.11.1
 ip nhrp registration no-unique
 ip tcp adjust-mss 1360
 tunnel destination x.x.x.163
 tunnel key 100000
interface Tunnel1
 bandwidth 24000
 ip address 11.11.12.2 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp map 11.11.12.1 x.x.x.163
 ip nhrp nhs 11.11.12.1
 delay 1001
 tunnel source FastEthernet1
 tunnel key 2
 description $ETH-WAN$
 ip address y.y.y.153 255.255.255.248
 ip nbar protocol-discovery
 ip nat outside
 ip policy route-map ips1
 duplex auto
 speed auto
 service-policy output CCP-QoS-Policy-1
interface FastEthernet1
 ip address z.z.z.185 255.255.255.248
 ip nat outside
 ip policy route-map isp2
 duplex auto
 speed auto
router eigrp 100
 redistribute static
 network 10.5.1.0 0.0.0.255
 no auto-summary
 neighbor 11.11.11.1 Tunnel0
 neighbor 11.11.12.1 Tunnel1
ip route 0.0.0.0 0.0.0.0 y.y.y.154
ip route 0.0.0.0 0.0.0.0 z.z.z.190 200
ip nat inside source route-map ips2 interface FastEthernet1 overload
ip nat inside source route-map ips1 interface FastEthernet0 overload
access-list 1 permit 10.5.1.0 0.0.0.255
access-list 1 permit 192.168.12.0 0.0.0.255
route-map ips2 permit 10
 match ip address 1
 match interface FastEthernet1
route-map ips1 permit 10
 match ip address 1
 match interface FastEthernet0
Marley Brown
 update on the hub:
sh crypto se
doesn't show tunnel1 just tunnel0
sh ip nhrp detail
11.11.12.2/32, Tunnel1 created 00:00:03, expire 00:03:01
  Type: incomplete, Flags: negative
  Cache hits: 3
sh crypto isa sa
doesn't show anything for the ip of isp2 on the spoke
on the spoke
sh crypto se
Interface: Tunnel1
Session status: DOWN-NEGOTIATING
Peer: 50.235.49.163 port 500
  IKE SA: local x.x.x..185/500 remote y.y.y.163/500 Inactive
  IPSEC FLOW: permit 47 host x.x.x.185 host y.y.y.163
        Active SAs: 0, origin: crypto map
sh ip nhrp detail
11.11.12.1/32 via 11.11.12.1
   Tunnel1 created 00:04:58, never expire
   Type: static, Flags:
   NBMA address: y.y.y.163
sh crypto isa sa
dst             src             state          conn-id status
50.235.49.163   x.x.x.153    QM_IDLE           2063 ACTIVE
50.235.49.163   y.y.y.185   MM_NO_STATE          0 ACTIVE
50.235.49.163   y.y.y.   MM_NO_STATE          0 ACTIVE (deleted)
