Showing results forĀ
Search instead forĀ
Did you mean:Ā
2 ospf processes on 1 router
Tuan Nguyen
I have a ring of 4 routers which I need to have 2 separate ring on the same devices. Thinking of running 2 different ospf processes. Is this the good practice? Thanks for the input
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
It's unclear what you're trying to really accomplish.
Multiple OSPF processes is unusual.
If you're looking for logical topology separation, you might be better served using VRFs.
Hi Joseph,
4 routers each has 4 interfaces: 2 40G and 2 10G to make 2 rings Traffic A is only on 40G and traffic B is only on 10G, I may have to redistribute some traffic between them.
Disclaimer
Posting
Ah, got it.
You should be able to use two OSPF processes like that.
Another alternative might be using PfR with PIRO (if supported on your routers).
