2 Questions about VRF-Lite
it's the first time i have to work with VRF and I have a couple of questions about VRF configuration.
1. I have two VRF (one for public addressing and another for private addressing mainly for management) and a shared Internet connection. I can configure 3 VRF (public, management and Internet) but for inter-VRF routing I must configure BGP. Other solution could be to use 2 VRF and let Internet connectivity out of any VRF. In this last case, it seems that I could use static routing for VRF-not_VRF routing. Is that true?
http://www.cisco.com/en/US/tech/tk436/tk832/technologies_configuration_example09186a0080231a3e.shtml
2. I have an interface with two IP addresses and I would like one IP address to be inside one VRF and another IP address to be inside other VRF. I think this is not possible with VRF-Lite...
Thanks in advance,
Christian
Edison Ortiz
1) Correct, per example you provided
2) Correct, you could use VRF Select but it requires full MPLS VPN
http://www.cisco.com/en/US/docs/ios/12_2/12_2sz/feature/guide/122szvrf.html
Edison
