2 routers vpn
benhakim10
Peace.
I'm trying to do vpn between two routers.
The first router model 1841
His dial settings is like this:
crypto isakmp policy 1
encr aes
authentication pre-share
group 2
crypto map hakim_to_yoni 10 ipsec-isakmp
set peer 81.218.161.32
set transform-set hakim_to_yoni
match address 101
interface FastEthernet0/1.200
ip mtu 1300
crypto map yoni_to_hakim 10 ipsec-isakmp
set peer 82.80.137.216
set transform-set yoni_to_hakim
match address 101
encr aes
group 2
crypto isakmp key 6 cisco address 81.218.161.32
crypto ipsec transform-set hakim_to_yoni esp-aes esp-sha-hmac
match address 101
ip mtu 1300
access-list 101 permit ip 10.80.5.0 0.0.0.255 192.168.185.0 0.0.0.25
my other is model c850
crypto isakmp key 6 cisco address 82.80.137.216
crypto ipsec transform-set yoni_to_hakim esp-aes esp-sha-hmac
match address 101
interface Tunnel40
ip address 192.168.205.1 255.255.255.0
access-list 101 permit ip 192.168.185.0 0.0.0.255 192.168.205.0 0.0.0.255
when i do:
show crypto session
Interface: FastEthernet0/1.200
Session status: DOWN
Peer: 81.218.161.32 port 500
  IPSEC FLOW: permit ip 192.168.205.0/255.255.255.0 192.168.185.0/255.255.255.0
        Active SAs: 0, origin: crypto map
  IPSEC FLOW: permit ip 10.80.5.0/255.255.255.0 192.168.185.0/255.255.255.0
6 Replies 6
On your second router, you have the crypto map on a tunnel-interface. Where does this tunnel go to? Or have you modified your config too much before posting here?
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
yes, i have tuneel with this settings:
interface Tunnel40
What's the destination and the purpose of that tunnel? The tunnel doesn't have a complete config and can't work.
sorry, this is the full config
interface Tunnel40
ip address 192.168.205.2 255.255.255.0
no ip redirects
ip mtu 1300
tunnel source BVI1
tunnel mode gre multipoint
That doesn't make any sense to me. Please describe what you want to achieve and include a deteiled drawing of your setup.
can i get your email ?
