2 routes to router - eigrp
paulnigel
Hi forum,
I am connecting 2 physical links to my router via 2 switches, the router is connected to all remote sites via EIGRP, How do I made the EIGRP to always choose the route with the riverbed steelhead optimizer, and only failover to the other link when the link to the Steelhead failed.
I put this on the switch port connected to router:
bandwidth 64000
delay 20
but the EIGRP still make use of the 2 routes, and I have asymmetric routes on the riverbed all the times..
The network layout is as attached.
Thank you very much,
pN
5 Replies 5
mohammedmahmoud
Level 11
Level 11
You can use the offset-list to increase the metric of the routes received from the other link in order to force it to act as backup.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800c2d96.shtml
HTH, please rate if it does help,
Mohammed Mahmoud.
EIGRP considers the parameters of the outgoing interface while calculating the metric and hence you need to manipulate the metrics on both sides of eigrp for proper operation
Can you post the configs of the 2811 and the L3 switches
Narayan
Hi Narayan,
the configuration of the core switch connected to the router is as append, the router has 2 ethernet ports, e0/1 is the one connected to the core switch, on the core switch side, i didnt do anything except setting one port to another vlan.
Thank you very much for your help, if you require further info, pls let me know.
pN
Router config:
interface FastEthernet0/1
ip address 172.16.165.5 255.255.255.0
ip nbar protocol-discovery
duplex auto
speed auto
interface Serial0/2/0
bandwidth 1984
ip address 172.16.212.1 255.255.255.0
ip flow ingress
max-reserved-bandwidth 100
service-policy output wan-qos
encapsulation ppp
ip route-cache flow
ip tcp header-compression iphc-format
compress stac caim 0
invert txclock
ip rtp header-compression iphc-format
router eigrp 100
network 172.16.0.0
network 192.168.5.0
network 192.168.62.0
network 192.168.121.0
network 192.168.123.0
network 192.168.254.0
default-metric 1000 100 255 1 1500
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.160.4
ip route 10.255.250.0 255.255.255.0 172.16.206.1
ip route 192.168.5.40 255.255.255.252 192.168.5.34
ip route 192.168.62.0 255.255.255.0 172.16.160.4
ip flow-export source FastEthernet0/0
ip flow-export version 5
ip flow-export destination 172.16.160.92 9996
ip flow-export destination 172.16.150.24 9996
Core switch:
interface Tunnel0
bandwidth 1000000
ip address 192.168.5.9 255.255.255.252
tunnel source 192.168.123.1
tunnel destination 192.168.62.1
interface Port-channel10
description Connection to Switch3560-Passive Switch - Rack 2
switchport mode trunk
no snmp trap link-status
interface GigabitEthernet0/6
description link to bypass Riverbed Steelhead - to delete after test with KMS
switchport access vlan 6
bandwidth 64000
delay 20
shutdown
interface GigabitEthernet0/7
spanning-tree portfast
interface Vlan1
ip address 172.16.160.21 255.255.255.0
ip helper-address 172.16.160.29
no ip redirects
load-interval 30
standby 1 ip 172.16.160.3
standby 1 priority 250
standby 1 preempt
router eigrp 100
network 172.16.0.0
network 192.168.5.0
network 192.168.122.0
no auto-summary
ip classless
ip route 172.16.170.42 255.255.255.255 192.168.5.10
ip route 192.168.62.0 255.255.255.240 172.16.160.4
no ip http server
ip http secure-server
Actually, you go into the secondary eigrp process and give it a higher distance.
Example
router eigrp 250
distance eigrp 100 180
exit
Defaults
internal-distance: 90
external-distance: 170
Therefore your primary eigrp process will continue to route and if the wan interface advertised in this process were to fail, it would route within the second eigrp process.
For example, you could have a gre tunnel configured for backup and advertise the routes in the secondary process.
In regards to your Tunnel, you can configure the second eigrp process as follows:
interface Tunnel0
bandwidth 1000000**** use 1402
ip mtu 1514 **** for overhead
eigrp 250
passive-inteface default
no passive-interface tunnel0
network 192.168.5.8 0.0.0.3
no auto
exit
also note:
you will have to redistribute the primary eigrp process into the secondary and tag it with a routemap, and then the other side of the wan you would do the same as well.
This is out scope for now, but please do a search for "Preventing Suboptimal Routes by Using Route Tags."
Cheers!
The riverbed will pass through the traffic at layer 1 (by electrically closing the switch between the two cables, in, out)
so a dead riverbed still works...
try it!
