2500 router Bad memory - wrote zero
sivakondalarao
I have 2500 series router. I have problem in booting up this router. Below is the console capture. Please do the needful.
System Bootstrap, Version 11.0(10c), SOFTWARE
Copyright (c) 1986-1996 by cisco Systems
Bad memory - wrote zero, read 0x80012002 at location 0x00000010
pompeychimes
Level 4
Level 4
1. If applicable remove all interfaces and reseat the memory
2. Try different 2500 memory
3. Try original memory in a diffrent 2500 router.
4. Throw Router away. 2500's aren't worth the hastle anymore.
Thanks for your reply. After reseating memory modules it started working.
SKR
