2600 s
aldoctors
hi
i have to know which (2600 series support the 16-NM Fiber port)ideal for the geteway redundancy(HSRP)?THESE SERIES Its reached End-of-Life (EOL) and End-of-Sale (EOS).
Merci
5 Replies 5
spremkumar
Level 9
Level 9
Do find the link which gives you the interfaces and modules supported by Cisco 2600 Series ,to be more precise on which model supports which interface/modules you need to lookupon on the datasheet which can give the compatibility matrix for different series.
http://cisco.com/en/US/products/hw/routers/ps259/products_relevant_interfaces_and_modules.html
The following models in Cisco 2600 have reached EOS/EOL status .
Cisco 2651 Multiservice Platform
Cisco 2650 Multiservice Platform
Cisco 2621 Multiservice Platform
Cisco 2620 Multiservice Platform
Cisco 2613 Multiservice Platform
Cisco 2611 Multiservice Platform
Cisco 2610 Multiservice Platform
for more info on those models do refer this link..
http://cisco.com/en/US/products/hw/routers/ps259/products_eol_models.html
regds
Hi spremkumar
All 26xx has reached EOL.which is the best that i'll consider to support fibergig port
Merci
Can you be more precise on whats your exact requirement.. do you need 16 Gig ports to be there in your router ? the kinda connecitivity you are going to have in place so that suitable chassis can be suggested.
Next model available in mid range is 2800 ISR series boxes but still it all depends upon the connectivity and the requirement..
regds
Thank U.I need 2 routers that support gigport.each of the 2 routers must be connected to 2 distribution(3560) switch via fiber cable lx/lh(distance 700M)
Thank U.
hi
In that case you can better go off with any of the 2800 series ISR models (except 2801)which accomdates HWIC-1GE-SFP port..
for more about HWIC-1GE-SFP do check this link out which talks about the SFP types which it can accomdate..
http://cisco.com/en/US/products/ps5854/products_data_sheet0900aecd8016be8d.html
regds
