2610xm does not recognize NM-ESW-16
jrh50fl
I'm trying to enable a NM-ESW-16 on my 2610xm running IOS c2600-i-mz.122-8.T5.bin. During boot the module is seen but that's all. Any suggestions would be appreciated.
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
00036C 0X000B3B80 C2620XM Single Fast Ethernet
0002A9 0X001F12AF 16 port ethernet switch
0X000F3BB0 public buffer pools
0X00211000 public particle pools
TOTAL: 0X005A99DF
6 Replies 6
marce1000
 - Check logs on the switch
 - Use latest advisory software version , check if that can help ,
 M.
Thank you for the response, however the "switch" module doesn't show up & what is the "latest advisory software version"?
What feature set is your 2610 running? This discussion suggests that IP Base does not support while Plus may.
https://community.cisco.com/t5/switching/2610-does-not-recognize-nm-esw-16/td-p/752049
Rick
Thank you Richard: My read on the link you provided, I should be able to use IP base 12.3 and higher, do you know which of these are GD or MD?
26xx/c2600-ipbase-mz.123-6a.bin 9280488
26xx/c2600-ipbase-mz.123-6b.bin 9281368
26xx/c2600-ipbase-mz.123-6c.bin 9282016
26xx/c2600-ipbase-mz.123-6f.bin 9283820
26xx/c2600-ipbase-mz.123-8.T.bin 11835984
26xx/c2600-ipbase-mz.123-9.bin 9439376
26xx/c2600-ipbase-mz.123-11.T6.bin 12055948
26xx/c2600-ipbase-mz.123-14.T7.bin 12450608
26xx/c2600-ipbase-mz.123-19.bin 9561276
26xx/c2600-ipbase-mz.123-22.bin 9569224
26xx/c2600-ipbase-mz.123-23.bin 9578364
26xx/c2600-ipbase-mz.123-25.bin 9582512
26xx/c2600-ipbase-mz.124-5.bin 12641392
26xx/c2600-ipbase-mz.124-8.bin 12492620
26xx/c2600-ipbase-mz.124-19.bin 12925808
26xx/c2600-ipbase-mz.124-25c.bin 12973432
26xx/c2600-ipbasek9-mz.124-3.bin 13257780
26xx/c2600-ipbasek9-mz.124-5.bin 13324160
26xx/c2600-ipbasek9-mz.124-8.bin 13169700
26xx/c2600-ipbasek9-mz.124-9.T.bin 14612996
26xx/c2600-ipbasek9-mz.124-10a.bin 13360616
26xx/c2600-ipbasek9-mz.124-12.bin 13374700
26xx/c2600-ipbasek9-mz.124-13.bin 13398840
26xx/c2600-ipbasek9-mz.124-13a.bin 13399212
26xx/c2600-ipbasek9-mz.124-13c.bin 13406924
26xx/c2600-ipbasek9-mz.124-15.T3.bin 15666528
26xx/c2600-ipbasek9-mz.124-17.bin 13594864
26xx/c2600-ipbasek9-mz.124-18.bin 13601764
26xx/c2600-ipbasek9-mz.124-19.bin 13615052
26xx/c2600-ipbasek9-mz.124-21.bin 13622936
26xx/c2600-ipbasek9-mz.124-23.bin 13650264
26xx/c2600-ipbasek9-mz.124-25b.bin 13660800
I am not sure of GD or MD. If you can get it I would think the most recent version would be the better choice: 26xx/c2600-ipbase-mz.124-25c.bin.
Rick
            >...what is the "latest advisory software version"?
  - Post the output on the 2610xm from the command : show version
 M.
