02-11-2011 08:53 PM - edited 03-04-2019 11:24 AM
i was just woundering if its possible to use a WIC-4ESW with a 2611 non-XM router?
with any IOS versions, i just want to know if its possibly or not.
Solved! Go to Solution.
02-11-2011 11:37 PM
Per my knowledge, WIC-4ESW is only for 1700 platforms. It not supported in 2600 platforms. You may have to consider NM-16ESW.
HTH,
Nagendra
02-11-2011 11:37 PM
HTH,
Nagendra
02-12-2011 05:52 AM
HTH,
Nagendra
i feel a biyt dumb for buying that WIC-4ESW, but i bought the NM-16ESW today, should get it this week, maybe thats why the WIC wasnt that expensive haha.
