02-11-2011 11:13 PM - edited 03-04-2019 11:24 AM
Hi every one.we have a 878 router and we want to mark traffics when entering on its lan interface.its lan interface is a layer 2 interface and we have created vlan interface and assosiated lan interface to that vlan.on vlan interface itself there is no service-policy command so we have to put serive-policy command on interace fast 0 itself which is layer 2 port.when we assign service-policy to fast 0 it doesnt work and it does not mark any traffic also class default counters doesnt increase to indicate any traffic is passing even it is not getting marked. ios version is advipservices.124.9T. so please guide me how to mark traffic on this port. ii dont know why service-policy command is supported on layer 2 interface when it doesnt work at all.how should i activate this ? thanks in advance
Solved! Go to Solution.
02-11-2011 11:22 PM
Can you explain the need for Layer2 QoS marking in your network? Using Layer2 QoS marking on routers is usually pointless because of two primary reasons:
Best regards,
Peter
02-11-2011 11:22 PM
Best regards,
Peter
02-11-2011 11:50 PM
Per my knowledge, Qos is not supported in vlan or L2 interfaces of 878.
Nagendra
02-12-2011 04:52 AM
thanks for reply. actually i dont wnat to use CoS bit marking,i want to use dscp marking but my problem is that this version of ios doesnt support service-policy on vlan interface,actually in 6500 switches we can use service-policy on vlan interfaces when we use command mls qos vlan base on layer 2 port itself.
But sofar i think service-policy command on interface fast in 870 router just let you mark based on CoS not DSCP. thank u guys.
