06-14-2005 10:48 AM - edited 03-03-2019 09:48 AM
we just got this WIC card and need help to config it. Please send us a link about it. Thank you very much.
Solved! Go to Solution.
06-14-2005 07:46 PM
You do. YOu physically connect the phone line for the DSL line (RJ11) into the RJ11 port on the wic-1adsl. Essentially DSL is PPPOE or PPPOA over atm. Insert the WIC-1adsl into the router and you will see an atm interface.
06-14-2005 11:51 AM
have a look at these documents:
1-Port ADSL WAN Interface Card Configuration
http://www.cisco.com/en/US/products/sw/iosswrel/ps5013/products_feature_guide09186a00800e79f3.html
Asymmetric Digital Subscriber Line (ADSL)
Cisco 1700/2600/3600 ADSL WIC Frequently Asked Questions
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_q_and_a_item09186a0080093bff.shtml
HTH,
GP
06-14-2005 01:30 PM
Dear Sir,
Your link is very valuable but I'm lost in this vast amount of information. All I have is a simple DSL service from SBC and want to replace the DSL modem with my Cisco 2611 router + WIC-1ADSL. Your first link is showing the config on an ATM interface which I don't think it's applicable to my case. Second link is too much to absorb. So could you please elaborate a bit more for me. Deeply appreciate your help.
06-14-2005 02:11 PM
Configs cut in short. This config has been tested with SBC ADSL line using PPPOE on a 1800.
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
interface ATM0/1/0
no ip address
no atm ilmi-keepalive
bundle-enable
dsl operating-mode auto
interface ATM0/1/0.1 point-to-point
pvc 0/35
pppoe-client dial-pool-number 1
interface Dialer1
ip address x.x.x.x
ip mtu 1492
encapsulation ppp
dialer pool 1
ppp authentication pap callin
ppp pap sent-username
ip route 0.0.0.0 0.0.0.0 Dialer1
ip classless
06-14-2005 03:49 PM
thank you, Sir. do I need to config the ATM interface eventhough I don't have one physically ?
06-14-2005 07:46 PM
06-14-2005 08:40 PM
thank you very much.
06-14-2005 08:05 PM
If you have enough DRAM/Flash and the proper IOS and all the hardwares work fine, you should be able to see an ATM interface for your WIC1-ADSL.
sh ver to see if you have an ATM interface. If not, check your DRAM/Flash and your current IOS feature set and version.
06-14-2005 08:41 PM
could you help with this issue ? DRAM/flash and IOS requirements. Thank you.
06-14-2005 10:06 PM
Do paste a sh version output in your next post.
06-14-2005 11:00 PM
12.0.3T
24M RAM
8M flash
06-15-2005 09:07 AM
You need a min of 12.2.T IP Plus. The below are the ones you can download (shows GD as well as Deferred releases)
General Deployment (GD)
and Limited Deployment (LD)
12.2.29 (GD)
12.2.28a (GD)
12.2.27a (GD)
12.2.26a (GD)
12.2.23e (GD)
12.2.12l (LD)
Deferred Release (DF)
12.2.27 (DF)
12.2.26 (DF)
12.2.24a (DF)
12.2.19c (DF)
12.2.12k (DF)
12.2.2-XN (DF)
12.2.29 requires 48 MB ram and 16 mb flash. I would suggest moving to a 12.3 train as the IOS is newer and free of bugs. 12.3 might need 64 Mb dram with same 16 mb flash.
Supported IOS versions can be found here.
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a0080088713.html
06-15-2005 01:25 PM
thank you very much. Have a good day.
