3640 power supply warning
rajeshk200_2
Hi all ,
i am getting error message in the console
Alarm description :
> ciscoEnvMonRedundantSupplyNotification received from enterprise
> ciscoEnvMonMIBNotificationPrefix with 2 arguments:
> ciscoEnvMonSupplyStatusDescr=700W AC; ciscoEnvMonSupplyState=warning
i issued the command it is showing everything is normal.
INMDRR01#sh env all
> Power Supply 1 is present.
> Thermal status: normal
> Input Voltage status: normal
> DC Output Voltage status: normal
> Power Supply 2 is present.
> Board Temperature: normal.
what could be the problem ?
thanx& regards,
Rajesh
wdrootz
Level 4
Level 4
I find quiet a lot of bugs listed with this error message in the Bug tool kit. See if one of them matches your problem.
