Showing results forĀ
Search instead forĀ
Did you mean:Ā
2620XM frame relay switch
gavin han
I've to configure 2620XM router as a frame replay switch. I need 8 interfaces on it. which module should I use?
I'll have other 7 routers connect to it using DB60 cross over cable. 6 of those routers will have WIC-2T card while 1 router will have  NM-4A/S card.
acampbell
Gavin,
If you can source it, you could use an NM-8A/S.
However you will only be able
to reach speeds upto 128K per interface
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
