2621 class-map for VoIP
gyalch
I am setting up QoS on our 2621s and need to setup a class-map to match traffic from either an ethernet interface on the router or hopped traffic with a specific source address. I have created an access-list for the source address but have run into a problem with the class map. I am trying to setup
class-map match-any MyClass
match input-interface ethernet1/0
match access-group 101
The problem is that when I try to enter this, the match-any or match-all commands don't seem to be available. It will only let me enter a class-map name and then one criteria. I am running 12.1(3a) with Plus. I'm not sure what I'm missing but any help would be great. Thanks.
peterson.dave
I would upgrade your level of code.
Thanks for your response. That brings about another question then is how do I go about obtaining a code update. I have never been able to find information about upgrading a software image and what is involved there. Thanks.
Your smartnet agreement should allow you to download a new image, which you can find in the IOS download center.
Then use the copy tftp flash command
