Can a VLAN have multiple IPs?
davebornack
This is what I want to achieve on a VLAN..
vlan 1
name "xxxx"
untagged A1-A16,B1-B24,D2-D24,F4
ip address 10.10.84.1 255.255.252.0
ip address 10.10.85.1 255.255.252.0
ip address 10.10.86.1 255.255.252.0
ip address 10.10.87.1.255.255.252.0
tagged E1-E4,F1-F3
no untagged C1-C24,D1
exit
davebornack
Or perhaps I need to assign each network to a seperate VLAN??
What if the ip address I assign is 10.10.84.1 255.255.252.0? This states 10.10.84.1-10.10.87.254... right?
Thanks in advance
What you should do will depend on what you are trying to achieve. And I am not clear from your description what you are really trying to achieve.
Yes you are correct that 10.10.84.1 255.255.252.0 does encompass addresses 10.10.84.1 through 10.10.87.254.
Rick
Rick
