2621 config for allowing PPTP to a RAS server *URGENT*
rbmclean
I need assisnatce in setting up a 2621 to allow only TCP 1723 and GRE 47 (MS VPN ports) to pass through to a specific internal server.
I have 1 static ip for the 2621 router.
I have set it up on fe0/0
fe0/1 is set up as 192.168.2.1
The RAS server is 192.168.2.2
How do I set up port forwarding or whatever to allow the 2 portocols and only them to be forwarded through to the RAS server?
Do I do ststic NAT mappings?
Robert
sh ver
IOS (tm) C2600 Software (C2600-IK8S-M), Version 12.2(11)T8, RELEASE SOFTWARE (f
c1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 28-Mar-03 18:31 by hqluong
Image text-base: 0x8000809C, data-base: 0x817E3CB4
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
ROUTER uptime is 16 minutes
System returned to ROM by reload at 00:08:29 DST Thu Jun 16 2005
System image file is "flash:10.0.0.125"
cisco 2621 (MPC860) processor (revision 0x102) with 56320K/9216K bytes of memory
Processor board ID JAB041709QS (2773658736)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
I am thinking you could just configure an access list allowing only those two ports to access the RAS server:
access-list 101 permit tcp any host 192.168.2.2 eq 1723
access-list 101 permit 47 any host 192.168.2.2
access-list 101 deny ip any host 192.168.2.2
access-list 101 permit ip any any
Could you try and see if that works for you ?
GP
