2621XM encapsulation question
willymaldonado1
while back I configure one of my cisco router on the stick, I remember getting the info over the net; and before I was a ble to  config the subint to an encapsulation I had to enable a command on the router, I did a mem erase on the unit, so now I need some help to get this router 2621XM enable it to run intervlans router ios c2600-i-mz.122-8.T10.bin, or it could be my other router ios c2600-ipbase-mz.123-6b.bin, I would really thankyou for your support...
2 Accepted Solutions
This is not supported on first IOS   c2600-i-mz.122-8.T10.bin, and supported on second  c2600-ipbase-mz.123-6b.bin.
Regards.
Alain.
IP Base does not support dot1q encapsualtion. You need IP Plus minimum.
If you do -
int fa0/0.10
encapsulatin dot1q 10
and it rejects the encapsulation command it is because it is not supported.
Jon
9 Replies 9
Reza Sharifi
Here is document that will explain it and provide config with examples:
You basicaly need to create a sub-interface with the .1q encapsulation under the sub-interface and also the ip
c2600(config)#int fastEthernet 0/0.2c2600(config-subif)#encapsulation dot1Q 2c2600(config-subif)#ip address 10.10.10.1 255.255.255.o
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a00800949fd.shtml
Reza, thanks for your prompt reply, I understand that part very well, and I am sorry I should have mention that the encapsulation command it is not recognized in my router and I get this message
Router(config-subif)#encap
% Invalid input detected at '^' marker.
Router(config-subif)#encap ?
% Unrecognized command
Do you have a way to enableling that command?
Regards.
Alain.
Thanks Alain, not matter where did i look for to find out if it was supported or not on any of my ios's... couldnt find it, so I thankyou for  that info; however as mentioned at the begining of my question, I belive that a command must to be enable on the router in order to be able to use the encapsulaton config under the subint, I tried to exec the encapsul command and keeps complaining
INTRT(config-subif)#encaps
INTRT(config-subif)#encapsulation
and that it's with the second ios the ipbase, does need to have like cef or cdp enable, I believe that it's a very simple task that needs to be done, so experts somewhere out there in the Cisco field I need your help here, I am on holt here to get a router on a stick going....
Willy,
Can you post "sh run" and "sh ver" from the router?
This is my config file
INTRT#sh run
Building configuration...
Current configuration : 6680 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname INTRT
logging count
no logging buffered
enable secret 5 $1$EaPd$5XPE6q/UCwJVMbCCgmNlb.
ip subnet-zero
no ip source-route
ip cef
no ip domain-lookup
no ip dhcp conflict logging
ip dhcp excluded-address 10.0.100.0 10.0.100.99
ip dhcp pool INTERNET
   network 10.0.100.0 255.255.255.0
   default-router 10.0.100.1 255.255.255.0
   dns-server 192.168.1.1
   lease 5
ip dhcp pool internet
no ip bootp server
interface FastEthernet0/0
ip address 192.168.10.11 255.255.255.0
ip access-group 102 in
ip access-group 100 out
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip route-cache flow
no ip route-cache cef
no ip mroute-cache
speed auto
full-duplex
no cdp enable
interface FastEthernet0/1
ip address 10.0.100.1 255.255.255.0
no ip proxy-arp
ip nat inside
no ip mroute-cache
speed 100
full-duplex
no cdp enable
interface FastEthernet0/1.1
no cdp enable
ip nat inside source list 100 interface FastEthernet0/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 0.0.0.0 0.0.0.0 192.168.10.10
ip route 0.0.0.0 0.0.0.0 172.17.0.1
no ip http server
no ip pim bidir-enable
no logging trap
access-list 23 permit 10.0.100.0 0.0.0.255
access-list 100 permit ip 10.0.100.0 0.0.0.255 any
access-list 100 permit ip any any
access-list 100 permit tcp 10.0.100.0 0.0.0.255 any eq www
access-list 100 permit tcp 10.0.100.0 0.0.0.255 any eq 3389
access-list 100 permit tcp 10.0.100.0 0.0.0.255 any eq ftp
access-list 100 deny   tcp any 10.0.100.0 0.0.0.255 eq cmd
access-list 100 deny   tcp any host 0.0.0.0 eq cmd
access-list 100 permit tcp 10.0.100.0 0.0.0.255 any eq 443
access-list 102 permit tcp any any gt 1023 established
access-list 102 permit tcp any any eq www established
access-list 102 permit udp any any eq domain
access-list 102 permit udp any eq domain any
access-list 102 permit tcp any any eq domain
access-list 102 permit tcp any eq domain any
access-list 102 deny   tcp any any eq ftp-data
access-list 102 deny   tcp any any eq telnet
access-list 102 permit tcp any 10.0.100.0 0.0.0.255 established
access-list 102 deny   ip 192.168.0.0 0.0.255.255 any log-input
access-list 102 deny   ip 172.16.0.0 0.15.255.255 any log-input
access-list 102 deny   ip 172.17.0.0 0.0.255.255 any log-input
access-list 102 deny   ip 10.0.0.0 0.255.255.255 any log-input
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any log-input
access-list 102 deny   ip 255.0.0.0 0.255.255.255 any log-input
access-list 102 deny   ip 224.0.0.0 31.255.255.255 any log-input
access-list 102 deny   ip host 0.0.0.0 any log-input
access-list 102 deny   icmp any any
access-list 102 deny   ip any any log-input
access-list 102 deny   ip 192.0.0.0 0.255.255.255 any log-input
access-list 102 deny   udp any any eq bootps
access-list 102 deny   udp any any eq tftp
access-list 102 deny   udp any any eq domain
access-list 102 deny   udp any any eq time
access-list 102 deny   udp any any eq tacacs
access-list 102 deny   udp any any eq 70
access-list 102 deny   udp any any eq 87
access-list 102 deny   udp any any eq sunrpc
access-list 102 deny   udp any any eq ntp
access-list 102 deny   udp any any eq snmp
access-list 102 deny   udp any any eq snmptrap
access-list 102 deny   udp any any eq 2049
access-list 102 deny   udp any any eq 6000
access-list 102 deny   udp any any eq 6001
access-list 102 deny   ip 10.0.0.0 0.0.0.255 any
access-list 102 deny   tcp any any eq gopher
access-list 102 deny   tcp any any eq 87
access-list 102 deny   tcp any any eq pop3
access-list 102 deny   tcp any any eq sunrpc
access-list 102 deny   tcp any any eq nntp
access-list 102 deny   tcp any any eq 123
access-list 102 deny   tcp any any eq 144
access-list 102 deny   tcp any any eq bgp
access-list 102 deny   tcp any any eq irc
access-list 102 deny   tcp any any eq 372
access-list 102 deny   tcp any any eq exec
access-list 102 deny   tcp any any eq login
access-list 102 deny   tcp any any eq cmd
access-list 102 deny   tcp any any eq lpd
access-list 102 deny   tcp any any eq talk
access-list 102 deny   tcp any any eq 520
access-list 102 deny   tcp any any eq uucp
access-list 102 deny   tcp any any eq 2000
access-list 102 deny   tcp any any eq 2001
access-list 102 deny   tcp any any eq 2002
access-list 102 deny   tcp any any eq 68
access-list 102 deny   tcp any any eq 6000
access-list 102 deny   tcp any any eq 6001
access-list 102 deny   tcp any any eq 6002
access-list 102 deny   udp any any eq echo log-input
access-list 102 deny   udp any eq echo any log-input
access-list 102 deny   udp any any eq 445
access-list 102 deny   udp any any eq netbios-dgm
access-list 102 deny   udp any any eq netbios-ns
access-list 102 deny   udp any any eq netbios-ss
access-list 102 deny   udp any any eq rip
access-list 102 deny   udp any any eq bootpc
access-list 102 deny   tcp any any eq 67
access-list 102 deny   ip any 0.0.0.255 255.255.255.0
access-list 102 deny   ip any 0.0.0.0 255.255.255.0
access-list 102 deny   tcp any host 0.0.0.0 eq cmd
access-list 102 deny   tcp any any eq cmd log
access-list 102 permit tcp any 10.0.100.0 0.0.0.255 established log-input
access-list 102 deny   tcp 192.168.10.0 0.0.0.255 any log
access-list 102 deny   tcp any 192.168.10.0 0.0.0.255 log
access-list 102 deny   udp any 192.168.10.0 0.0.0.255 log
access-list 102 permit udp 192.168.1.0 0.0.0.255 any eq bootpc
access-list 102 permit udp 192.168.1.0 0.0.0.255 any eq bootps
access-list 102 deny   tcp any 192.168.10.0 0.0.0.255 eq 445 log-input
access-list 102 deny   udp any any eq 23
access-list 102 deny   tcp any any eq 123 log
access-list 102 deny   tcp any any eq 123 log-input
access-list 102 deny   udp any any eq 23 log-input
access-list 102 deny   tcp any any eq telnet log-input
access-list 102 permit udp host 132.163.4.103 eq ntp 10.0.100.0 0.0.0.255 log-in
put
access-list 102 deny   tcp any host 10.0.100.1 eq cmd log-input
access-list 102 deny   udp 192.168.1.0 0.0.0.255 any eq bootps
access-list 102 deny   udp 192.168.1.0 0.0.0.255 any eq bootpc
no cdp run
line con 0
exec-timeout 0 0
password 7 071724404F5B495446
logging synchronous
login
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 2 0
password 7 05130303201E1E58484F5D5D44
login
line vty 5 15
access-class 23 in
login
end
THIS IS MY ROUTER VER
INTRT#sh ver
IOS (tm) C2600 Software (C2600-I-M), Version 12.2(8)T10,  RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 30-May-03 02:45 by kellythw
Image text-base: 0x80008074, data-base: 0x80A2C2B0
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
INTRT uptime is 1 hour, 9 minutes
System image file is "flash:c2600-ipbase-mz.123-6b.bin"
cisco 2621XM (MPC860P) processor (revision 0x300) with 93184K/5120K bytes of mem
ory.
Processor board ID JAE0821J2B2 (2834618551)
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
If you do -
int fa0/0.10
Jon
Thank you all!! I will try a different ios.... and how could i close this question
Willy
You don't actually close a question as such.
If your question has been answered then you can use the ratings buttons to show that.
Jon
