04-24-2008 04:13 AM - edited 03-03-2019 09:41 PM
Hi all,
I have one issue with my 2621XM router.
When a tried to insert "interface mfr" command, router just reloded and repported following error message:
System returned to ROM by error - a SegV exception, PC 0x80468584
Cisco says
ERROR: This router was restarted by a Segmentation Violation Exception (SegV). This is caused by a software related problem. The most common software issues that can cause a Segmentation Violation Exception are: - Access to an invalid memory address - Write access to a read-only memory region - A jump to an invalid PC (often 0x0)
I tried to software upgrade router but i have still same issue
I want to configure some MFR interfaces and frame-relay encapsulation.
Here follows some more details from sh tech:
Sh ver:
IOS (tm) C2600 Software (C2600-IS-M), Version 12.2(13)T, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Sat 16-Nov-02 23:00 by ccai
Image text-base: 0x80008098, data-base: 0x8183511C
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
NO001550NROU01 uptime is 1 day, 20 hours, 49 minutes
System restarted at 18:28:11 SUM Tue Apr 15 2008
System image file is "flash:c2600-is-mz.122-13.T.bin"
cisco 2620XM (MPC860P) processor (revision 0x100) with 94208K/4096K bytes of mem ory.
Processor board ID JAE07300121 (364871735)
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
------------------ show stacks ------------------
Minimum process stacks:
Free/Size Name
5600/6000 SPAN Subsystem
2588/3000 allegro libretto init
8216/12000 Init
5440/6000 RADIUS INITCONFIG
8976/12000 Virtual Exec
Interrupt level stacks:
Level Called Unused/Size Name
1 47156100 8356/9000 Network interfaces
2 0 9000/9000 Timebase Reference Interrupt
3 0 9000/9000 PA Management Int Handler
6 4 8916/9000 16552 Con/Aux Interrupt
7 39886646 8920/9000 MPC860 TIMER INTERRUPT
System was restarted by error - a SegV exception, PC 0x80468584
Stack trace from system failure:
FP: 0x82C0D100, RA: 0x804691EC
FP: 0x82C0D118, RA: 0x80468758
FP: 0x82C0D138, RA: 0x803BEC54
FP: 0x82C0D168, RA: 0x815EAB54
FP: 0x82C0D190, RA: 0x815EADDC
FP: 0x82C0D1A0, RA: 0x815EC784
FP: 0x82C0D1C8, RA: 0x80942D80
FP: 0x82C0D200, RA: 0x8001C2B0
04-24-2008 06:50 AM
A SegV exception can be almost anything, but almost invariably a bug. For example, I had one in my lab over the weekend due to an IPv6 access list that it did not like ... that was on 12.4(2)T, also on a 2611XM as it happens.
I found this in the bug database that might be relevant, but I don't know whether you have traffic shaping anywhere:
CSCdz38482 Bug Details Bug #3 of 6 | < Previous | Next >
Router crashes with SegV exception
Symptoms: A Cisco router that is configured for Multilink Frame Relay (MFR)
may reload when traffic shaping is enabled on an MFR interface.
Conditions: This symptom is observed only when one of the MFR bundle links is
configured after traffic shaping has been enabled.
Workaround: There is no workaround.
The only thing I can suggest is save the config to a file, clear down the config completely, configure the MFR first, then gradually introduce the rest of the config until you find the bit it is clashing with. That's the way I found my IPv6 access-list bug.
Kevin Dorrell
Luxembourg
