2690 switch turning poe on and off on a single port
roncro
Level 3
Level 3
is it possible to  turn on/off poe on a single port on a 2690s switch?  (I want to restart a device that runs on  poe).
thanks,
Ron
Martin L
You meant c2960 switch, right? you should just bounce the port (shut, no shut); is that not an option?
Cisco Doc says you cannot turn off PoE per port but there are 2 commands.
energywise level 0
where 0 is no power, 1-hibernate,2-standby, etc.  Try /test it to see if that works.  If that does not work or it;s not supported, look at other option such as
power inline
power inline never
(use ? to find more)
Regards, ML
**Please Rate All Helpful Responses **
9 Replies 9
Leo Laohoo
Either disable the port or use the command
power inline NEVER
to turn PoE off.  To turn PoE back on,
no power inline never
I want to do that for only one specific port though,  not all ports.  So what would the command be for that?
If no one is going to read and understand our response(s), it does not matter nor make any difference.
You mean like, not understand this one?
I do not have the capacity to write long and fluffy responses.  My responses are short and easy-to-understand.
My first response answers the question very accurately about how to disable PoE on a specific port.  All it takes is for someone to read it and understand it.
To do so, apply that command under port interface, aka interface mode
config t
interface FastEthernet0/1
power inline never
exit
but not under global mode
Config t
Martin L
energywise level 0
power inline
power inline never
Regards, ML
Yes,  a C2690S  I can do that,  BUT  does that keep the port configuration intact so I don't have to re-configure that port again?
Yes, port configuration will remain intact when u shut and no shut port and Also when u run command
power inline never
to erase configuration from port u would have to use
interface xyz default
command, or manually add no like following
in front of any command u want apply.
