2800 Interface Question
Patrick McHenry
Level 4
Level 4
I have a Cisco 2811 router. It is currently being used for a 10mb encrypted, ELAN WAN connection to a remote site via a built-in FE port. It is connected to our core via the other built-in FE port. The ports used are Fasterthernet 0/0 and 0/1. From the output I provided, if I were to install another 2-port fastethernet card in one of the free slots, is there a way to tell if I will be able to create another encrypted tunnel using that new card? I'm concerned because of the 3rd line of output below. - NAME: "Virtual Private Network (VPN) Module on Slot 0", DESCR: "Encryption AIM Element"
I'm wondering if I am only allowed to create VPNs on Slot 0.
If that is true, could I create the Encrypted interfaces that connect to the sites on Slot 0, and use the LAN ports on the new slot?
Thanks, Pat.
Router#sh inventory
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811         , VID: V07 , SN: FTX1406A1DS
PID: AIM-VPN/SSL-2     , VID: V01, SN: FOC13511HF3
Router#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(24)T2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 19-Oct-09 17:38 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
EXIT8PT-2811 uptime is 1 day, 6 hours, 14 minutes
System restarted at 05:07:18 EST Mon Jan 30 2012
System image file is "flash:c2800nm-advipservicesk9-mz.124-24.T2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.50) with 512000K/12288K bytes of memory.
Processor board ID FTX1406A1DS
2 FastEthernet interfaces
2 Virtual Private Network (VPN) Modules
DRAM configuration is 64 bits wide with parity enabled.
191K bytes of non-volatile configuration memory.
126976K bytes of ATA CompactFlash (Read/Write)
5 Replies 5
Pat
You should be able to create another encrypted tunnel if you install additional FastEthernet card in the router. The AIM-VPN/SSL-2 in slot 0 is a hardware assist for encryption processing which relieves the CPU from having to do much of the crypto processing. The slot 0 that it is in is not the same as the slot for the FastEthernet Cards.
Rick
Rick
Richard,
Thanks for the response. I'm not sure what I should order to a slot on the 2811. Is there a module that is specific for that router or will any cisco, 2 port, fastethernet module do?
Thanks, Pat.
