03-28-2007 04:59 AM - edited 03-03-2019 04:20 PM
We will have 4mbps link. do 2821 or 2851 Router support 4 mbps link or should we have higher router?
03-28-2007 05:02 AM
Friend,
Yes they do.
Actually even a 2801 would support 4 Mbps.
I would suggest you decide considering future requirements.
HTH,
NArayan
03-28-2007 05:12 AM
Thanku
03-28-2007 05:21 AM
Lalit,
Please find the link below for the router performace. Based on the throughput in Mbps you can decide which router will suffice your requierement.
http://www.cisco.com/warp/public/765/tools/quickreference/routerperformance.pdf
HTH,Please rate if it does.
-amit singh
