2801 router and 4 port lan card
DJCanuck1_2
I want to use my 4 port lan card on my 2801 ISR as my Internet access switch. I have an ASA 5505 that I'd like to redirect the traffic to on a separate provider that the 2801. Is there any special setup for the four interfaces on the LAN module? Internal workstations can browse the web, but my DMVPN tunnel is down.
b.henshaw
Could you provide a bit more technical detail please? A diagram would be helpful, and also a [sanitised] configuration and a few points on what you think should be happening versus what is actually happening/not working.
