Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
What you might be missing is a 2811 can not handle a T3 at full rate. From personal experience, had a 2811 hit 100% CPU at about 20 Mbps (duplex) across a T3.
Since a 2851 offers about twice the performance of a 2811, it's probably the smallest router that could "safely" handle a T3.
Although Cisco might recommend something faster than your 2951 for a full T3, since it's, I believe, faster than a 3845 which also was recommended for T3s, likely it will work fine.
Since even the 2901 is faster, I believe, than a 2851, any 29xx might be able to handle a single T3.
