BGP Over VPn reset Exactly every three mins
wrobbin
From my Main Router
Code
c2800nm-advsecurityk9-mz.124-15.T3.bin
Jul  7 09:53:53: %BGP-5-ADJCHANGE: neighbor 10.10.242.130 Down BGP Notification sent
Jul  7 09:53:53: %BGP-3-NOTIFICATION: sent to neighbor 10.10.242.130 4/0 (hold time expired) 0 bytes
Jul  7 10:03:30: %BGP-5-ADJCHANGE: neighbor 10.10.242.130 Up
Jul  7 10:07:36: BGP: 10.10.242.130 open failed: Connection timed out; remote host not responding, open active delayed 34483ms (35000ms max, 28% jitter)
Branch router
Code
c2800nm-advsecurityk9-mz.124-24.T5.bin
From Debug
Jul  7 08:03:23: BGP: 10.128.7.30 open active, local address 10.10.242.130
Jul  7 08:03:30: BGP: 10.128.7.30 read request no-op
Jul  7 08:03:30: BGP: 10.128.7.30 went from Active to OpenSent
Jul  7 08:03:30: BGP: 10.128.7.30 sending OPEN, version 4, my as: 1, holdtime 180 seconds
Jul  7 08:03:30: BGP: 10.128.7.30 send message type 1, length (incl. header) 53
Jul  7 08:03:30: BGP: 10.128.7.30 rcv message type 1, length (excl. header) 26
Jul  7 08:03:30: BGP: 10.128.7.30 rcv OPEN, version 4, holdtime 180 seconds
Jul  7 08:03:30: BGP: 10.128.7.30 rcv OPEN w/ OPTION parameter len: 16
Jul  7 08:03:30: BGP: 10.128.7.30 rcvd OPEN w/ optional parameter type 2 (Capability) len 6
Jul  7 08:03:30: BGP: 10.128.7.30 OPEN has CAPABILITY code: 1, length 4
Jul  7 08:03:30: BGP: 10.128.7.30 OPEN has MP_EXT CAP for afi/safi: 1/1
Jul  7 08:03:30: BGP: 10.128.7.30 rcvd OPEN w/ optional parameter type 2 (Capability) len 2
Jul  7 08:03:30: BGP: 10.128.7.30 OPEN has CAPABILITY code: 128, length 0
Jul  7 08:03:30: BGP: 10.128.7.30 OPEN has ROUTE-REFRESH capability(old) for all address-families
Jul  7 08:03:30: BGP: 10.128.7.30 OPEN has CAPABILITY code: 2, length 0
Jul  7 08:03:30: BGP: 10.128.7.30 OPEN has ROUTE-REFRESH capability(new) for all address-families
BGP: 10.128.7.30 rcvd OPEN w/ remote AS 4
Jul  7 08:03:30: BGP: 10.128.7.30 went from OpenSent to OpenConfirm
Jul  7 08:03:30: BGP: 10.128.7.30 went from OpenConfirm to Established
Jul  7 08:03:30: %BGP-5-ADJCHANGE: neighbor 10.128.7.30 Up
0109_Aurora_CO_2811#
Than After 3 mins exactly the session will go to idle than stay stuck in Active....
Jul  7 08:06:32: BGP: 10.128.7.30 connection timed out 180884ms (last update) 180000ms (hold time)
Jul  7 08:06:32: BGP: 10.128.7.30 went from Established to Closing
Jul  7 08:06:32: %BGP-5-ADJCHANGE: neighbor 10.128.7.30 Down BGP Notification sent
Jul  7 08:06:32: %BGP-3-NOTIFICATION: sent to neighbor 10.128.7.30 4/0 (hold time expired) 0 bytes
Jul  7 08:06:32: BGP: 10.128.7.30 send message type 3, length (incl. header) 21
Jul  7 08:06:32: BGP: 10.128.7.30 local error close after sending NOTIFICATION
Jul  7 08:06:32: BGPNSF state: 10.128.7.30 went from nsf_not_active to nsf_not_active
Jul  7 08:06:32: BGP: 10.128.7.30 went from Closing to Idle
Jul  7 08:06:32: BGP: 10.128.7.30 closing
Jul  7 08:06:50: BGP: 10.128.7.30 went from Idle to Active
Jul  7 08:06:50: BGP: 10.128.7.30 open active, local address 10.10.242.130
Jul  7 08:07:20: BGP: 10.128.7.30 read request no-op
Jul  7 08:07:20: BGP: 10.128.7.30 open failed: Connection timed out; remote host not responding, open active delayed 3642ms (5000ms max, 90% jitter)
Jul  7 08:07:24: BGP: 10.128.7.30 open active, local address 10.10.242.130
Jul  7 08:07:54: BGP: 10.128.7.30 read request no-op
Jul  7 08:07:54: BGP: 10.128.7.30 open failed: Connection timed out; remote host not responding, open active delayed 5336ms (10000ms max, 60% jitter)
Jul  7 08:07:59: BGP: 10.128.7.30 open active, local address 10.10.242.130
Giuseppe Larosa
Hello Wrobbin,
this looks like a problem of recursive routing: once the BGP session up one router starts to think that it can reach the external IP address in another way.
3 minutes is exactly the default BGP hold time.
once the BGP session is up connectivity is broken and so after three minutes the side that didn't receive any BGP message for 180 seconds sends out a BGP notification message.
Be sure that the external networks are not advertised over the BGP session
Hope to help
Giuseppe
