2811 99% CPU High IP Input
nfordhk
Our 2811 Edge router is having extremely high CPU problems. IP Input is consuming 70% of the process during business hours. Cisco express forwarding is enabled. It only shows 50% but its currently before business hours. Id say even 50% is still high.
CPU utilization for five seconds: 55%/16%; one minute: 70%; five minutes: 76%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
104     5310320     2813117       1887 36.92% 46.73% 51.43%   0 IP Input
The below interface is our public interface and is constantly over utilized with 100% Is there any configurations that can be done to correct this? Is there any more information that is needed? Please indicate any command if it can be done live as this is production and I cannot take it down on whim.
IOS: (C2800NM-ADVSECURITYK9-M), Version 12.4(24)T4
Show IP Interface
FastEthernet0/0 is up, line protocol is up
  Internet address is x.x.x.x
  Broadcast address is x.x.x.x
  Address determined by non-volatile memory
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Outgoing access list is ******************
  Inbound  access list is ******************
  Proxy ARP is disabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are never sent
  ICMP unreachables are never sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF switching turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is disabled
  BGP Policy Mapping is disabled
  Input features: Stateful Inspection, Ingress-NetFlow, Access List, MCI Check
  Output features: Stateful Inspection, CCE Post NAT Classification, QoS Drop, IPsec or interface ACL checked on pre-encrypted cleartext packets, Post-Ingress-NetFlow
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
R-NUS-IRVINE#sh int fa0/0
  Hardware is ************ Ethernet, address is *************
  Description: *******************
  Internet address is **********************
  MTU 1500 bytes, BW 2048 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 132/255, rxload 168/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 4/75/213/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: Class-based queueing
  Output queue: 0/1000/0 (size/max total/drops)
  30 second input rate 2183000 bits/sec, 503 packets/sec
  30 second output rate 1066000 bits/sec, 436 packets/sec
     3417553 packets input, 984199842 bytes
     Received 850 broadcasts, 0 runts, 0 giants, 75 throttles
     848 input errors, 0 CRC, 0 frame, 0 overrun, 848 ignored
     0 watchdog
     4432507 packets output, 3406178496 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
interface FastEthernet0/0
description *****************
bandwidth 2048
ip address ***************** *****************
ip access-group ******************
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
load-interval 30
duplex auto
speed auto
no mop enabled
service-policy output ***************
5 Replies 5
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the  information contained within this    posting without consideration and  with the reader's understanding that    there's no implied or expressed  suitability or fitness for any  purpose.   Information provided is for  informational purposes only and  should not   be construed as rendering  professional advice of any kind.  Usage of  this  posting's information  is solely at reader's own risk.
Liability Disclaimer
In     no event shall Author be liable for any damages whatsoever   (including,   without limitation, damages for loss of use, data or   profit) arising  out  of the use or inability to use the posting's   information even if  Author  has been advised of the possibility of  such  damage.
Posting
Have you reviewed http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00801c2af3.shtml?
Yes I did, I did not feel any of those problems pretained to my router
Hi Nicholas,
try to enabled debug ip packet detail as indicated in the doc to see which type of traffic is being process-switched. that will help understand what is going on.
Riccardo
Hello Dears,
I have same problem as reported above. I have Cisco2811 and having same CPU utilization. as i examined , i found two process take cpu resources 1. IP input and ARP input. please tell me the solution. thanks.
show processes cpu
CPU utilization for five seconds: 82%/75%; one minute: 76%; five minutes: 76%
   1     1765856    660333       2674  0.00%  0.00%  0.00%   0 Chunk Manager
   2      912092     82732      11024  0.32%  0.19%  0.15%   0 Load Meter
   4           0         1          0  0.00%  0.00%  0.00%   0 EDDRI_MAIN
   5     3265804    138426      23592  0.00%  0.18%  0.21%   0 Check heaps
   6        9588      2258       4246  0.00%  0.00%  0.00%   0 Pool Manager
   7           0         2          0  0.00%  0.00%  0.00%   0 Timers
   8           0         1          0  0.00%  0.00%  0.00%   0 chkpt message ha
   9           0         1          0  0.00%  0.00%  0.00%   0 OIR Handler
  10           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
  11       55672     13756       4047  0.00%  0.00%  0.00%   0 Environmental mo
  12        1760      6887        255  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  13           0         1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  14      112132    389461        287  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  15      107364    389455        275  0.00%  0.00%  0.00%   0 IPC Deferred Por
  16           0         1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  17           0         1          0  0.00%  0.00%  0.00%   0 IPC BackPressure
  18     4534248   3144033       1442  0.32%  0.31%  0.32%   0 ARP Input
  19      183808    405827        452  0.00%  0.00%  0.00%   0 ARP Background
  20           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  21           4         2       2000  0.00%  0.00%  0.00%   0 AAA high-capacit
  22           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  23           0         1          0  0.00%  0.00%  0.00%   0 Policy Manager
  24           4         2       2000  0.00%  0.00%  0.00%   0 DDR Timers
  25           4         2       2000  0.00%  0.00%  0.00%   0 Entity MIB API
  26       11508      6934       1659  0.00%  0.00%  0.00%   0 EEM ED Syslog
  27       94828    121114        782  0.00%  0.00%  0.00%   0 HC Counter Timer
  28           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  29           0         1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  30           0         1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  31           0         2          0  0.00%  0.00%  0.00%   0 SMART
  32      128040    410628        311  0.00%  0.00%  0.00%   0 GraphIt
  33           0         2          0  0.00%  0.00%  0.00%   0 Dialer event
  34           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  35           0         2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  36           0         2          0  0.00%  0.00%  0.00%   0 cpf_process_msg_
  37           0         1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  38           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  39      388128    379421       1022  0.00%  0.01%  0.00%   0 Net Background
  40           0         2          0  0.00%  0.00%  0.00%   0 IDB Work
  41       17068     11731       1454  0.00%  0.00%  0.00%   0 Logger
  42      170556    389432        437  0.00%  0.00%  0.00%   0 TTY Background
  43      691424    415384       1664  0.08%  0.03%  0.02%   0 Per-Second Jobs
  44        7160     27448        260  0.00%  0.00%  0.00%   0 c2800 Periodic
  45           0         1          0  0.00%  0.00%  0.00%   0 IKE HA Mgr
  46           0         1          0  0.00%  0.00%  0.00%   0 IPSEC HA Mgr
  47        2056        26      79076  0.00%  0.00%  0.00%   0 rf task
  48      122568    155877        786  0.00%  0.00%  0.00%   0 Net Input
  49      125816     83977       1498  0.00%  0.00%  0.00%   0 Compute load avg
  50      737388      8028      91852  0.00%  0.01%  0.00%   0 Per-minute Jobs
  51           0         1          0  0.00%  0.00%  0.00%   0 AggMgr Process
  52           0         1          0  0.00%  0.00%  0.00%   0 Token Daemon
  53           0         1          0  0.00%  0.00%  0.00%   0 dev_device_inser
  54           0         1          0  0.00%  0.00%  0.00%   0 dev_device_remov
  55           0         1          0  0.00%  0.00%  0.00%   0 sal_dpc_process
  56           0         1          0  0.00%  0.00%  0.00%   0 ARL Table Manage
  57           0         2          0  0.00%  0.00%  0.00%   0 ESWPPM
  58           0         2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
  59           0         2          0  0.00%  0.00%  0.00%   0 ESWILPPM
  60           0         2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
  61      407984   1470636        277  0.00%  0.02%  0.00%   0 Netclock Backgro
  62           0         2          0  0.00%  0.00%  0.00%   0 SM Monitor
  63           0         2          0  0.00%  0.00%  0.00%   0 Bryce I2C CMD Qu
  64         272         4      68000  0.00%  0.00%  0.00%   0 USB Startup
  65       23356     68145        342  0.00%  0.00%  0.00%   0 mxt5100
  66           0         2          0  0.00%  0.00%  0.00%   0 VNM DSPRM MAIN
  67           0         1          0  0.00%  0.00%  0.00%   0 DSPFARM DSP READ
  68           0         2          0  0.00%  0.00%  0.00%   0 FLEX DNLD MAIN
  69           0         1          0  0.00%  0.00%  0.00%   0 HDV background
  70           0         2          0  0.00%  0.00%  0.00%   0 VMI Background
  71           0         1          0  0.00%  0.00%  0.00%   0 RF_INTERDEV_DELA
  72           0         1          0  0.00%  0.00%  0.00%   0 RF_INTERDEV_SCTP
  73       80696    389455        207  0.00%  0.00%  0.00%   0 Ether-Switch RBC
  74           0         1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Pr
  75           0         1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Re
  76        3304     13757        240  0.00%  0.00%  0.00%   0 Call Management
  77           0         1          0  0.00%  0.00%  0.00%   0 AAL2CPS TIMER_CU
  78           4         1       4000  0.00%  0.00%  0.00%   0 CES Line Conditi
  79           0         1          0  0.00%  0.00%  0.00%   0 CF_INTERDEV_SCTP
  80           0         4          0  0.00%  0.00%  0.00%   0 HWIC FE Link Mon
  81           0         2          0  0.00%  0.00%  0.00%   0 Dot1x Mgr Proces
  82           0         1          0  0.00%  0.00%  0.00%   0 MAB Framework
  83           0         1          0  0.00%  0.00%  0.00%   0 EAP Framework
  84           0         2          0  0.00%  0.00%  0.00%   0 DTP Protocol
  85       76212    389448        195  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
  86        8580     41074        208  0.00%  0.00%  0.00%   0 EtherChnl
  87           0         2          0  0.00%  0.00%  0.00%   0 Ethernet CFM
  88      134396    382172        351  0.00%  0.00%  0.00%   0 Ethernet Timer C
  89       98100    389471        251  0.00%  0.00%  0.00%   0 linktest
  90           0         2          0  0.00%  0.00%  0.00%   0 Dot11 Mgmt & Ass
  91           0         2          0  0.00%  0.00%  0.00%   0 Dot11 aaa proces
  92        3360      6887        487  0.00%  0.00%  0.00%   0 pmkid
  93           0         2          0  0.00%  0.00%  0.00%   0 Dot11 auth Dot1x
  94           0         1          0  0.00%  0.00%  0.00%   0 Dot11 Mac Auth
  95           0         2          0  0.00%  0.00%  0.00%   0 AAA Server
  96           0         1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  97     1710572   8928330        191  0.16%  0.16%  0.16%   0 ACCT Periodic Pr
  98           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
  99       89312     59111       1510  0.00%  0.00%  0.00%   0 CDP Protocol
 100           0         2          0  0.00%  0.00%  0.00%   0 Ethernet OAM Pro
 101           0         2          0  0.00%  0.00%  0.00%   0 Ethernet LMI
 102         148       157        942  0.00%  0.00%  0.00%   0 IP ARP Adjacency
 103     1726464   8928269        193  0.08%  0.14%  0.16%   0 IP ARP Retry Age
 104   130440600  14268741       9141  3.52%  3.00%  4.13%   0 IP Input
 105           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
 106           0         4          0  0.00%  0.00%  0.00%   0 TurboACL
 107           0         2          0  0.00%  0.00%  0.00%   0 TurboACL chunk
 108           0         1          0  0.00%  0.00%  0.00%   0 IPv6 RIB Redistr
 109        1456       686       2122  0.00%  0.00%  0.00%   0 MOP Protocols
 110           0         3          0  0.00%  0.00%  0.00%   0 PPP Hooks
 111        1008       166       6072  0.16%  0.23%  0.08% 514 Virtual Exec
 112           0         1          0  0.00%  0.00%  0.00%   0 SSS Manager
 113       15184     54899        276  0.00%  0.00%  0.00%   0 SSS Test Client
 114           0         1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
 115      499584   1464068        341  0.00%  0.02%  0.02%   0 SSS Feature Time
 116           0         1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
 117           0         6          0  0.00%  0.00%  0.00%   0 SSM connection m
 118           0         1          0  0.00%  0.00%  0.00%   0 AC Switch
 119         100         2      50000  0.00%  0.00%  0.00%   0 EAPoUDP Process
 120           0         2          0  0.00%  0.00%  0.00%   0 IP Host Track Pr
 121           0         2          0  0.00%  0.00%  0.00%   0 KRB5 AAA
 122      102268     53881       1898  0.00%  0.00%  0.00%   0 IP Background
 123        5640      6892        818  0.00%  0.00%  0.00%   0 IP RIB Update
 124           0         2          0  0.00%  0.00%  0.00%   0 PPP IP Route
 125           0         2          0  0.00%  0.00%  0.00%   0 PPP IPCP
 126           0         2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
 127           0         2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
 128           4         2       2000  0.00%  0.00%  0.00%   0 Dot1x Supplicant
 129           0         1          0  0.00%  0.00%  0.00%   0 Asy FS Helper
 130      186500    373039        499  0.00%  0.00%  0.00%   0 Socket Timers
 131       20556     15069       1364  0.00%  0.00%  0.00%   0 TCP Timer
 132       11304      2491       4537  0.00%  0.00%  0.00%   0 TCP Protocols
 133           0         1          0  0.00%  0.00%  0.00%   0 COPS
 134      256720    520961        492  0.00%  0.02%  0.01%   0 CEF process
Disclaimer
Posting
BTW, if your IOS supports it, sorted would have been a nice option to use when displaying your CPU stats.
Hmm, looking at your stats .  .  .
Most of your utilization appears to be interrupt CPU.  What's the aggregate traffic load?
You're really worried about ARP Input at 3/10 of a percent?
IP Input isn't too high.  Maybe a little higher than we would like.  Generally, it represents non fast-path packet forwarding.  It can have many causes, including the nature of the traffic.  Have you reviewed the whitepapers on troubleshooting high IP Input?
