2811: Not detecting WIC
sudip.acharya1
I installed a new WIC (vers.2) in a 2811 but I do not see a serial port available to configure. I restarted, still no luck.
Sho Diag does see the wic installed. I tried moving it a another slot but the same thing, Sho Diag saw it in the new slot but its not available.
IOS: 12.4(13r)T11
Do the wic's need to be "activated" or something?
Thanks.
yourname#sho diag
Slot 0:
C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
Onboard VPN : v2.3.3
EEPROM contents at hardware discovery:
PCB Serial Number : xxxxxxxxxxx
Hardware Revision : 1.0
Top Assy. Part Number : 800-26920-05
Board Revision : A0
Deviation Number : 0
Fab Version : 04
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20090808
Chassis Serial Number : xxxxxxxxxxx
Chassis MAC Address : 0023.xxx.xxxx
MAC Address block size : 24
CLEI Code : COMWL10CRA
Product (FRU) Number : CISCO2811
Part Number : 73-10258-05
Version Identifier : V06
EEPROM format version 4
EEPROM contents (hex):
WIC Slot 2:
VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1
Hardware Revision : 0.0
Top Assy. Part Number : 800-22628-05
Board Revision : C0
Fab Version : 04
PCB Serial Number : FOC13354W75
RMA History : 00
You are welcome, please remember to rate useful posts with the scrolbox below.
7 Replies 7
paolo bevilacqua
Configure "card-type E1 2"
Then "controller E1 2/0".
Note:
12.4(13r)T11 That is not IOS version, it's Rommon version.
Thanks.
I am not able to run the 2nd part of the command, 2/0 should have taken care of it.
vers(config)#card type t1 0 2
vers(config)#controller t1 2/0
% Invalid input detected at '^' marker.
vers(config)#controller t1 2-0
vers(config)#controller t1 0/2
vers(config)#
So check show controllers T1 then.
finally got it up, its:
controller T1 0/2/0
framing esf
linecode b8zs
cablelength long 0db
Thanks for your help.
One more question,
under sho Conf, that port shows up add "Tunnel 1", is that correct? I was expecting to s/0/0 or something. Also, I cant set encapsulation to PPP.
Your configuration is not complete and you need the 'channel-group' command in order to allocate the time-slots from the T1.
Once you do that, your serial interface will show up
http://www.cisco.com/en/US/docs/ios/dial/command/reference/dia_c1.html#wp1013268
Edison
