01-23-2012 05:58 AM - edited 03-04-2019 02:59 PM
I have installed am ATM module in a 2821 router, but I have no chance to put the command 'mode atm aim 1'
murotuer(config)#controller E1 0/3/0
myrouter(config-controller)#mode ?
cas Configure CAS (Channel Associated Signal) mode
ccs Configure CCS (Common Channel Signal) mode
myrouter#sh diag
AIM Module in slot: 1
Hardware Revision : 1.0
Top Assy. Part Number : 800-27059-01
Board Revision : A0
WIC Slot 3:
E1 (2 port) Multi-Flex Trunk WAN daughter card
Hardware revision 1.0 Board revision A0
Serial number 36554718 Part number 800-04479-05
Version Identifier V02 FRU Part Number VWIC-2MFT-E1
IOS: flash:c2800nm-advipservicesk9-mz.124-24.T4.bin
I have tried in both ATM ports but nothing changed.
Any idea why I dont' have the mode ATM command?
Regards and thanks
Solved! Go to Solution.
01-23-2012 07:49 AM
Sorry that was bad use of copy & paste by me.
I should have pasted this :-
NAME: "Virtual Private Network (VPN) Module on Slot 1", DESCR: "Encryption AIM Element"
PID: AIM-VPN/SSL-2 , VID: V01, SN: FO
This is for VPNs and SSL
As I said this is the wrong type of AIM for ATM support
You need the AIM-ATM variant
Alex
01-23-2012 06:51 AM
I think you may have the wrong kind of AIM card
Can you post show inven
Alex
01-23-2012 06:57 AM
myrouter#sh inv
NAME: "2821 chassis", DESCR: "2821 chassis"
PID: CISCO2821 , VID: V03 , SN: FTXxxx
NAME: "2nd generation two port FXS voice interface daughtercard on Slot 0 SubSlot 0", DESCR: "2nd generation two port FXS voice interface daughtercard"
PID: VIC2-2FXS , VID: V01 , SN: FOCxxx
NAME: "2nd generation two port FXS voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "2nd generation two port FXS voice interface daughtercard"
NAME: "2nd generation two port FXS voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "2nd generation two port FXS voice interface daughtercard"
PID: VIC2-2FXS= , VID: V , SN: FOCxxx
NAME: "Two port E1 voice interface daughtercard on Slot 0 SubSlot 3", DESCR: "Two port E1 voice interface daughtercard"
PID: VWIC-2MFT-E1 , VID: V02, SN: xx
NAME: "PVDMII DSP SIMM with Two DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with Two DSPs"
PID: PVDM2-32 , VID: V01 , SN: FOCx
NAME: "8-port Analog Modem Card Version 2 on Slot 1", DESCR: "8-port Analog Modem Card Version 2"
PID: , VID: 1.0, SN: F
01-23-2012 07:08 AM
This is your issue.
This is NOT for ATM support.
You need
AIM-ATM variant
Alex
01-23-2012 07:46 AM
Sorry, but I don't understand 'NAME: "8-port Analog Modem Card Version 2 on Slot 1", DESCR: "8-port Analog Modem Card Version' is for dial up access.
I need to configure the ATM for the VWIC-2MFT-E1 card.
Regards and thanks
01-23-2012 07:49 AM
Alex
