2821 HWIC-4T1/E1 configuration/software support
Patrick Laidlaw
Level 4
Level 4
I have two  HWIC-4T1/E1 in two 2821's  I can not for the life of me find software so I can configure them in the routers. I see them in the inventory but don't see them in show ver.  I'm assuming that the software is not recognizing them.  I've tried a bunch of releases that software advisor says they are supported and am wondering if I'm just doing something wrong.
NAME: "4 port clear channel T1/E1 HWIC on Slot 0 SubSlot 0", DESCR: "4 port clear channel T1/E1 HWIC"
PID: HWIC-4T1/E1       , VID: V02 , SN: xxxxxxxxxx
NAME: "Two port T1 voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "Two port T1 voice interface daughtercard"
PID: VWIC-2MFT-T1=     , VID: 1.0, SN: xxxxxxxxxx
Cisco 2821 (revision 53.51) with 245760K/16384K bytes of memory.
Processor board ID xxxxxxxx
2 Gigabit Ethernet interfaces
2 Channelized/Clear T1/PRI ports
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
If anyone has experience with them please let me know.  I would expect them to show up as a normal controller that I would then just configure.
-Patrick
Patrick Laidlaw
Level 4
Level 4
Well Hell just figured it out its sitting right there in the config telling me to post the card type.    typed into the configuration
"Card type t1 0 0"  and it works yeah.
LOL
